Results 1 to 15 of 15
Thread: Rotolock Valves
Hybrid View
22-12-2005, 07:05 PM #1
Rotolock Valves
Why dont Le Unite Hermetique design the valve so one can hold the valve securely with a wrench on one side whilst tightening the nut onto the compressor body.
How do you tighten yours??
Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
22-12-2005, 07:49 PM #2
Re: Rotolock Valves
I just put the wrench onto the nut and hold the pipe. If the flare knacks I make a new one, but more often than not the flare stays good.
and go get a cuppa
22-12-2005, 08:55 PM #3
Re: Rotolock Valves
Originally Posted by Aiyub
22-12-2005, 09:00 PM #4
Re: Rotolock Valves
securely with a wrenchput the wrenchthe adjustable wrenchesan adjustable spanner
Does anybody own or ever use a proper spanner set?
and go get a cuppa
22-12-2005, 10:28 PM #5
Re: Rotolock Valves
Originally Posted by chillin out
23-12-2005, 07:14 AM #6
Re: Rotolock Valves
I remove the plastic stem cap and slide a box spanner along the threads, mine is big enough to clear the threads with out damaging them and slides straight onto the round part after the threads, have done it like this for years on roto locks. I use to use a ring spanner the same way but found the box spanner to be much better in tight spaces.
23-12-2005, 08:22 AM #7
Re: Rotolock Valves
That's the way I'm doing it.
Perhaps this is a box spanner.
Took the picture yesterday evening on a scrap compressor.
Bought the whole set spanners (keys?) for +/- 20€, not quality tools but they're good for what I'm using them.
You can make this in fact yourself Aiyub with a short piece of iron tube and weld a rod on it. The valves are allways the same size.
Or use a threated 1/2" T-piece (drill a litlle bit wider, just remove the threads)like they use in heating systems and screw in the T a tube of 1 inch long as a handle. See last picture I took 5 minutes agoLast edited by Peter_1; 23-12-2005 at 08:35 AM.
22-12-2005, 09:20 PM #8
Re: Rotolock Valves
yes i have a spanner set imperial and metric and use it on specific jobs, good for rebuilding compressors etc as adjustables can somtimes round corners on bolts.
Zimbo
23-12-2005, 12:02 PM #9
Re: Rotolock Valves
Hey guys, How do you loosen and tighten your gland nuts in tight spaces???
I had a boiler maker make me a special tool about 35mm long from hardened steel with a 50mm handle welded to it. Is there a product out there designed for the job or do most use nut f*ckers (adjustable spanners).
23-12-2005, 09:35 PM #10
Re: Rotolock Valves
Originally Posted by dogmaBrian - Newton Abbot, Devon, UK
24-12-2005, 03:11 PM #11
Re: Rotolock Valves
Me, I just leave my hands in my pockets and hope that no-one is looking
and go get a cuppa
08-02-2006, 12:28 AM #12
Re: Rotolock Valves
will need to grab the tire iron next compressor change out
08-02-2006, 05:18 PM #13
Re: Rotolock Valves
The tyre wheel nut spanner might just be the job!!
The Unite is a brilliant compressor.......
But a real lousy rotolock valveAny opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
Stainless steel valves
By Tycho in forum NH3Replies: 5Last Post: 05-11-2008, 02:16 PM -
Hinari and how far to open valves
By stryker in forum Air ConditioningReplies: 6Last Post: 14-04-2008, 01:47 AM -
Suction Stop Valves
By frank in forum Air ConditioningReplies: 10Last Post: 02-08-2006, 11:04 PM -
Glycol water valves
By eng_ab in forum IndustrialReplies: 2Last Post: 03-06-2005, 09:15 PM -
Positon of tx valves
By Les Stuart in forum Trouble ShootingReplies: 5Last Post: 16-11-2003, 04:43 PM
