Results 1 to 12 of 12
Thread: If my remote has no display
03-08-2012, 01:43 PM #1
is it dead , or a problem elswhere ?
Its a daikin remote ... has no readout at all, and the system is not working.
has power.
03-08-2012, 01:49 PM #2
Re: If my remote has no display
it is dead...Or possibly not, who knows unles syou can be there to see.
Time for yellow pages.
03-08-2012, 02:04 PM #3
thank you , ill order one right away
03-08-2012, 02:11 PM #4
03-08-2012, 02:12 PM #5
put some batteries in it.
03-08-2012, 02:17 PM #6
03-08-2012, 02:32 PM #7
it is wall mounted
03-08-2012, 02:33 PM #8
I was just being flipant as usual! But as RB states the manual/test run button would confirm it will run.
Personally i'd phone daikin tech and ask what to test to see if the remote or unit is faulty (having firsts checked fuses, connections, mcbs, outdoor unit for led codes etc)Mostly found in Oxfordshire, UK :)
03-08-2012, 02:33 PM #9
and also has power, the reset button on the pcb wont reset
03-08-2012, 02:34 PM #10
is there a reset on the remote , the manual, isnt clear
03-08-2012, 03:21 PM #11
03-08-2012, 08:11 PM #12
the button on the indoor enables auto mode ,setpoint 24 and low fan
theres a reset button o the remote where the batteries are or on the back. if youve got no display on the controller and youve changed the batteries,and the batteries are in the correct way and no scale in the battery terminals then u need new controller-prob dropped
