Thread: Sanyo p29 fault
    Mar 2011
    34
    101
    14
    Sanyo p29 fault
    Hi all one of my friends has a Sanyo ac system which is displaying p29 fault any idea what the fault is and what parts are req to fix thiis
    Jun 2009
    Lusk , Dublin
    1,115
    Re: Sanyo p29 fault
    P29 is a compressor fault or DCCT failure ,It basically telling you the inverter compressor failed to start.
    Model numbers make this a whole lot easier....
    Stu
    Tool's ? check ! Condom's ? check !
    Nov 2008
    nepal
    125
    Re: Sanyo p29 fault
    Quote Originally Posted by mattym View Post
    give me your email address i will send the PDF file including codes of VRF
    Oct 2007
    manchester
    5,639
    45
    Re: Sanyo p29 fault
    click on mattym then click view profile, then click about me then click download v card- member details are there
    Quote Originally Posted by anil130 View Post
    Nov 2008
    nepal
    125
    Re: Sanyo p29 fault
    many many thanks brother..
    Quote Originally Posted by install monkey View Post
    Aug 2009
    Romania
    8
    Re: Sanyo p29 fault
    You need to check the HIC board and also to measure the windings of the inverter (hope you have some ohms on each windings). If its broken you can stll run the machine until you replace it using the dipswitch on MB.
