Thread: mitsubishi fault
12-12-2005, 08:09 PM #1
mitsubishi fault
Has any body come across a fault on Mitsubishi cassette unit U8?
12-12-2005, 08:22 PM #2
Re: mitsubishi fault
My "k series" manual saya the follwing:
"U8 is no fault (factory setting)"
U faults are generally to do with outdoor units,
has the outdoor unit pcb been replaced and not setup properley????
does the unit run??
12-12-2005, 08:28 PM #3
further to my last post
if the display is actually "UA" or "U6" this is compressor overcurrent
also if you have confused with daikin (a U8 on their equip is transmission errror between controllers)
15-12-2005, 08:49 PM #4
Units runs ok but stops after a couple of days and U8 comes up when you press check button. indoor unit continues to run, press on / off button and it comes back to normal. Have cleared fault on outdoor board.
Techni
22-12-2005, 07:42 PM #5
in the book it says abnomality of outdoor fan motor
so it it is either the fan motor or the pcb
23-12-2005, 11:28 AM #6
Hi Techni
U8 is a factory generated code it means nothin if you press the check button and this shows it means there are no faults in the error history. If the unit is stopping and no fault is showing intermittendly then if its a K series check the control voltage on the interconnecting terminals if the voltage is down around 10 volts DC then when the compressor starts there is a voltage drop and the outboard locks up but no fault shows. Hence the u8 its a difficu;lt one to sort as its the starting draw on the compressor that causes the drop U may have tofit a 12 volt Dc power supply to the outdoor and use the existing control signal to switch some small relays for control. I have also had it when the remote conrrol cable is passing over emrgency lighting in the ceiling the signal gets interrupted by the magnitic field around the power supplies for the lights just reroute the cable if this the case.
hope this helps
regards
T
23-12-2005, 11:30 AM #7
Excuse the spelling Christmas party last nightIm suffering badly
Mitsubishi vrv
By dakesojo in forum Air ConditioningReplies: 20Last Post: 22-09-2009, 01:04 PM -
Chigo Cpa-09co Fault Codes? E4?
By chigosimon in forum Trouble ShootingReplies: 5Last Post: 24-11-2007, 12:46 AM -
Diplomat 6528 Fault Code
By Targus in forum DomesticReplies: 3Last Post: 31-10-2006, 07:43 PM -
Chiller fault
By iceman007 in forum Trouble ShootingReplies: 9Last Post: 27-06-2006, 06:15 AM -
Chiller Fault
By iceman007 in forum Air ConditioningReplies: 2Last Post: 13-05-2006, 07:23 PM
