    Apr 2010
    295
    automatic charging recovery machine
    Hi guys
    my company has just purchased and had delivered a Texa konfort 760R bus vehicle charging and recovery unit with a vacume pump fitted but the are no set up instructions as in how to initially put R134a into the machine how to use nitrogen with it how to connect a gas bottle to it if you have to in fact there is very little technical info with the dam thing is there anyone who can help by sending me or posting on here diagrams or instructions your help would be very much appreciated
    simon
    I can fix broke but I cant fix stupid :)
    manchester
    5,639
    Re: automatic charging recovery machine
    posh kit- is it spider proof??
    cant find any instructions-found uk contact info
    Postal Address
    Eclipse Automotive Technology Ltd
    Eclipse House
    Granary Wharf
    Wetmore Road
    Burton on Trent
    DE14 1DU
    United Kingdom
    Email Eclipse
    sales(at)eclipse-tech.co.uk
    Telephone
    Lo-call: 08454 66 66 99
    Int'l: +44 1283 249810
    Sales: Option 1
    Tech Support: Option 2
    Customer Services: Option 3
    Fax
    Lo-call fax: 08454 66 59 86
    Int'l: +44 1283 536 320
    Apr 2010
    295
    cheers mate i will email you the manual i have as i know you collect them its not much use though
    manchester
    5,639
    still waiting for your old vac pump as you definatly dont need it now u got a posh machine with a built in vac pump and gas analyser!!
    Apr 2010
    295
    but i have no idea how the dam thing works lmao so i need it
    manchester
    5,639
    http://youtu.be/rmYUlGUN-T0
    found this-vid- if this actor can operate it then u dont need a manual- it just needs a spider with its 2079 to connect to the system and select the type of bus and press go! haha
    Apr 2008
    Southampton, England
    49
    1,023
    Mean piece of kit.
    If it's anything like the types I've used (Robinair) the database should hold charge info so you can select the correct vehicle and let it do its thing.
    Oil and UV dye is normally added manually when the circuit is under vacuum.
    No option with OFN. Leak testing is done when the system is under vacuum and the machine will wait a preset time to see if the vacuum rises or not to complete a leak test.
    To add refrigerant you will need to put the machine into some sort of revovery mode and suck in some fresh refrigerant.
    No instructions? Has your boss been down Peckham Market? My old garage got the sales guy in to run through how to use our old machines but even they came with some paperwork.
    Cheers,
    Andy.
    manchester
    5,639
    think of all the r22 you can reclaim out of them 134a systems-ur gonna be loaded!!
    Dec 2010
    Toronto, Canada
    1,454
    If simon has a POSh machine, does that mean he must keep the sun to his left leaving his house? (Ohoh, too much beer alert)
