12-12-2005, 07:35 AM #1
help with mitsubishi starion 82 model car a/c
I have been asked to look at a Mitsubishi Starion a/c
82 model car
any ideas where i could find the specs on the system for oil volume , refrigerant charge
was on r12 but will change to 134a with poe oil
how much oil and refrigerant will be needed.
The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
12-12-2005, 08:31 AM #2
Re: help with mitsubishi starion 82 model car a/c
You could ofcourse consider using a "drop in" refrigerant so save you changing the oil.
Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
12-12-2005, 08:31 AM #3
Originally Posted by fridg
cheers
richard
12-12-2005, 09:54 AM #4
The system has been open for around 2 months so using the old oil is not a good idea
i have come across the specs for the 88 starion , just seeing if there was some solid information on the 82
I work in manufacturing of display cases so the prefered refrigerant is R134a
Yes i will have to change oil to P.O.E
thanks for the advice guys !The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
12-12-2005, 10:38 PM #5
Originally Posted by fridgBrian - Newton Abbot, Devon, UK
Mitsubishi vrv
By dakesojo in forum Air ConditioningReplies: 20Last Post: 22-09-2009, 01:04 PM -
Mitsubishi problem
By marc5180 in forum Trouble ShootingReplies: 15Last Post: 17-01-2007, 10:06 PM -
Daikin Model
By Geofridgee in forum Air ConditioningReplies: 1Last Post: 12-07-2006, 09:23 AM -
mitsubishi heat pump
By Mark in forum Air ConditioningReplies: 4Last Post: 17-01-2004, 10:43 AM -
UK TV Show looking for model makers / engineers
By roadshow in forum HobbiesReplies: 1Last Post: 30-12-2003, 03:16 PM
