Results 1 to 19 of 19
Thread: Lae SDU11
Threaded View
06-12-2005, 09:05 PM #1
Lae SDU11
Hi to all
This is my first post so be gentle with me.
I need some help with a controller wiring.
I am trying to make a curing cupboard like the one in the link
http://home.pacbell.net/lpoli/htm%20...ty_control.htm
I have acquired a fridge freezer and a controller.
The problem I have is how do I wire the controller?
It is a Lae SDU11.
I contacted Lae and they gave me the wiring diagram below.
Apparently it is the same as the SDU12.
But the wiring diagram does not tell me which is live in or out, which is neutral and so on.
I was going to use the controller to turn the fridge/freezer on and off via the main supply to give me the temp I require. But after thinking about it I am wondering if I could use it to just operate the freezer section thus leaving me with the fridge as normal.
Thank for your help Steve
z_sdu12.gifLast edited by hunterman; 06-12-2005 at 09:08 PM.
