Thread: Semi-Hermetic compressors
26-11-2005, 02:14 PM #1
While changing some unloader valves I noticed oil pooled on top of some of the pistons.How much is acceptable if any.
Regards Bernard.
26-11-2005, 08:14 PM #2
Re: Semi-Hermetic compressors
Hi Bernard.
There are always small oil quantities on the pistons.
If liquid is pulled into the crankcase, then it washes the oil out through the discharge.
Chemi
26-11-2005, 08:32 PM #3
Thanks chemi
If I did a complete oil change on a pack and filled the compressors up to 3/4 on the sight glasses and the reciever.Would this be the correct amount.
Thankyou Bernard
27-11-2005, 12:49 AM #4
Sounds fine but watch out for carrier comps they like 1/4 full sight glass. Most comps copeland etc are 1/2 to 3/4 full.
27-11-2005, 09:52 AM #5
How true Snowman and yes i am new to the to this site and hello to everyone
27-11-2005, 06:13 PM #6
Hi Bernard,
When you change oil in a compressor, measure the amount you took out, fill up the same amount unless it was low before.
Always remember to clean the oil filter as well.
Chemi
29-11-2005, 08:46 PM #7
Originally Posted by Toosh
WelcomeEngineering, sciences, math, physics and my brain will generate "not responding " soon
do we need a hermetic or semi hermetic comp.?
By duraid in forum FundamentalsReplies: 14Last Post: 17-04-2007, 05:52 PM -
Part Wound Semi Hermetic Compressors
By bernard in forum ElectricalReplies: 9Last Post: 22-12-2005, 06:33 PM -
Bock AM5 compressor's shaft seal failiure
By Gareth in forum Trouble ShootingReplies: 11Last Post: 05-04-2004, 09:12 PM -
Compressor's volume efficiency
By John McGru in forum FundamentalsReplies: 0Last Post: 16-02-2004, 08:44 AM -
Compressors
By Abe in forum Chit Chat & Service StoriesReplies: 0Last Post: 10-09-2001, 12:49 AM
