Results 1 to 17 of 17
    Nov 2011
    Wales, UK
    Daikin Altherma HT - Theft protection
    Hi All,
    I'm having a Daikin Altherma HT installed next week and am a bit concerned over the outdoor unit and hydrobox being outside. We live near a road and people will be able to see the installation passing by.
    We havent full decided whether to have them freestanding or whether to have the up against the gable wall.
    Is there anyway of securing the unit to the ground or house wall?
    Any suggestions?
    Dec 2009
    Re: Daikin Altherma HT - Theft protection
    dont worry no one will nick it it weighs about half a ton the boys will never be able to lift it
    Nov 2011
    Wales, UK
    well if it can be carried in, i'm worried it can be carried out!
    Any security suggestions?
    Jun 2009
    Lusk , Dublin
    1,115
    Bolt it to.the ground, if on a solid surface and fit a security cage.
    Failing that get a BFD.
    Stu
    Nov 2011
    Wales, UK
    Thanks, whats a BFD?
    Jun 2009
    Lusk , Dublin
    1,115
    Sorry thats a joke.
    BFD stands for
    Big F*#king Dog.
    Your installer should be able to provide you with a security cage.
    Stu
    Jul 2009
    essex
    47
    Security cage for the is that lol
    Jul 2009
    essex
    47
    surposed to say is that for the dog lol
    Nov 2011
    Wales, UK
    haha! Dog would do it.
    The installers say it will have a pea gravel soak away so not sure how I can bolt it. Maybe cage agaisnt the wall would work.
    It's going to add £100+ to add it to my home insurance!!
    Jun 2009
    Lusk , Dublin
    1,115
    Ideally the unit would be raised off the ground on a frame or mounted on brackets on the wall ,believe me you do not want it on a bed of pea gravel ,water lodging in the base of these machines is well known to cause serious problems during cold weather,free drainage is the key,a drain pan heater is available I believe.
    Prefabricated cages are available from most good equipment suppliers ,similar to these
    http://www.pumphousepumps.com/GroupInfo.aspx?Id=171
    C
    heers
    Stu
    Dec 2008
    563
    I thought that Daikin recommend a minimum of 100mm space between the base of the unit and the ground surface to ensure that free drainage occurs.
    Jun 2009
    Lusk , Dublin
    1,115
    Obviously the bloke who wants to set it on a bed of gravel did not bother to RTFM.
    Stu
    Quote Originally Posted by hyperion View Post
    Apr 2011
    35
    Lay slabs on a bed of hardcore, drill through through middle of the feet and anchor to the concrete/cement mix, fix unit to feet and grind corners of the bolts? no one will take it with out spending a couple hours! cheaper and looks better then a cage! shingle round the slabs is a must to
    5,667
    Quote Originally Posted by wiffola View Post
    Hi All,
    Are you aware that the Hydrobox is not weatherproof and is designed to be fitted indoors?
    Oct 2010
    Poland
    13
    As I went through the topic just waited who would bring this up... Hydrobox should be inside...
    The out door unit has to be mounted quite a bit above ground... there's lot of water ( ice ) accumulating during winter time. And I guess a good bracket/rack, wall mount and secured bolts of the feet unit should make it difficult to take off... Plus they have to cut pipies going to the indoor unit...
    Nov 2011
    Wales, UK
    its in a weather tight insulated box. Custom made. I wouldnt want that noisey thing in the house it would drive me insane!
    Nov 2011
    Wales, UK
    Quote Originally Posted by Steven_AC View Post
    Thanks for the advice - I only just read this (after our installation) but this is exactly how it has been installed. Drilled out cross head screws to be exact. I feel a lot less worried about security now it's all installed. But it's all added to the house insurance without an increase in premium. They just stipulated that the outdoor unit was bolted to the concrete base and the hydrox box enclosure was locked with a padlock. The concrete bases had to located agaisnt the house. They wouldnt cover the units being away from the wall of the house. So thats worked out well.
    Thanks for your help.
