    Dns's Avatar
    Dns Guest
    Smile Refrigerant recovery system
    Have anyone of you DIY refrigerant recovery system, how can this be done. Are we able to purify 100%.
    Dec 2009
    Spain
    45
    229
    15
    Re: Refrigerant recovery system
    Hi DNS,
    we produce a cleaning system that also can recover and recycle any halocarbon refrigerant.
    The purity of recycled refrigerants is less than 600ppm in the worst of cases, which is R-22, due to its miscibility with the own compressor of our system.
    I'll be glad to give you more details.
    Aug 2007
    Sydney
    52
    1,083
    23
    For a diy you can use a small condensing unit with filter driers. You need to be careful of oil so if you are only recovering say r22 use and r22 condensing unit and install a burnout drier/suction line filter before compressor. Most recovery units use (vertually) oilless compressors. Also an oil seperator is used.
    One company I worked for used a giant still to clean R11 with an open drive compressor. It really depends on how much you want to recover and how portable the unit needs to be. I guess if it is for smaller units you would be best to buy a reclaim unit. If it is for recovering refrigerant from chillers in buildings you could build one that would work faster than the common reclaim units on the market.
    Sep 2003
    ISRAEL
    72
    4,248
    If there was no demand for recovery units, they wouldn't be around.
    I don't see why not to buy one good unit. They come with a special oil less compressor that can handle liquid, build in oil separator that pushes the oil out to a small container.
    All you have to change is the small inlet filter.
    We don't need to build ourselves every gadget for work when the machine that was designed and built for that purpose is in a distance of a phone call.
  1. Daikin fault codes
    By Chris2005 in forum Air Conditioning
    Last Post: 21-03-2012, 10:09 PM
  2. System Burn Out Troubleshooting
    By altaf22m in forum Technical Discussions
    Last Post: 07-05-2010, 09:24 AM
  3. CARE refigerants by BOC
    By dogma in forum Refrigerants
    Last Post: 23-03-2010, 12:39 PM
  4. Replies: 19
    Last Post: 15-04-2008, 07:03 PM
  5. Linde Pack, Oil recovery system.
    By buddy in forum Supermarket Refrigeration
    Last Post: 05-01-2007, 03:04 AM
