Results 1 to 17 of 17
16-12-2011, 09:53 AM #1
Sanyo - Triangle with an ! in a triangle fault. Any advice?!
Hi All,
First time post so lets start with a (hopefully) easy one.....
We have a Triangle with a exclaimation mark in the middle, on a Sanyo SHA-HC64AGB system.
The system is working fine but we want to clear the fault. Any advice?
Thanks X
16-12-2011, 10:49 AM #2
Re: Sanyo - Triangle with an ! in a triangle fault. Any advice?!
Don't worry !
Sorted
16-12-2011, 06:00 PM #3
But did you figure out what the fault was ???
Or did you just drop the power and re power??
17-12-2011, 04:10 PM #4
Its a System I/O request from the main processor for a game of snooker
23-12-2011, 12:42 PM #5
It's either
a 2-pipe system and the indoor unit with the controller showing this display is not working in the priority mode.
or the outdoor unit has shut down the inverter compressor due to a problem. This should leave the fixed speed compressors running.
Can't find anything in the manuals about snooker
Loops
06-01-2012, 02:27 PM #6
xoudus
Keep this too yourself mate but the triangle with exclamation mark is a caution symbol!!
Think it is something related to the inverter comppressor exceeding a predetermined current at 80hz.
cheers phil
06-01-2012, 02:34 PM #7
06-01-2012, 02:43 PM #8
Stu
Had that problem before on a previos job, and i would say it is still there....Long list of excuses for it, but i remember T duff reduced the max hz to try solve it, with no joy!!
If you hear of any top trups for this one let me know,
cheers phil
06-01-2012, 03:03 PM #9
Had it myself Phil ,Tony recommended wiping the error history hasn't come back since.
08-01-2012, 10:23 AM #10
Stu
How did you wipe the memory!?? Will come in handy.
Phil
08-01-2012, 10:36 AM #11
Pressing CL (Clear) button will clear all
the service history.
https://rapidshare.com/files/9353306...0063-00_11.pdf;
for service manualLast edited by install monkey; 08-01-2012 at 10:41 AM.
08-01-2012, 09:00 PM #12
Thanks install
19-01-2012, 05:31 PM #13
Thanks for the advice guys, much appreciated. We just dropped the power Stu and everything seems to be working fine now.
We keep having issues identifing faults on Sanyo kit though, it looks like the list of fault codes we have is out of date. Any advice on where to source a list of godly content?
19-01-2012, 09:47 PM #14
Happy Christmas
https://rapidshare.com/files/1087597..._2WAY_TRSM.PDF
https://rapidshare.com/files/4172254...SERVICE_...PDF
https://rapidshare.com/files/2525042746/SUPER_ECO.pdf
https://rapidshare.com/files/1694654...LITS_R407C.pdf
https://rapidshare.com/files/1306697...TS_R407C_2.pdf
https://rapidshare.com/files/2589893...TS_R407C_3.pdf
https://rapidshare.com/files/1322692...TS_R407C_4.pdf
20-01-2012, 01:10 PM #15
Thanks Stu, will try and download them when I'm home. The work computer doesn't want to play ball.....
28-02-2012, 11:29 PM #16
Does anyone know how to clear RC 1-1 display on Sanyo split ipac DC inverter ?
I have changed a faulty condenser motor and main outdoor PCB.
29-02-2012, 12:24 AM #17
Did u swap the eeprom on the old PCB to the New one JJ . If not u have to plug an RC into the new PCB and program it. Gis a call in the am and I'll talk u tru it 00353872696043
T
