Thread: Fridge Stop working sometime
29-11-2011, 05:55 PM #1
Hi everyone,
I have a Beko Frost Free with independent Freezer, but the fridge is too small so I think that they are using both the same compressor. The problem is that sometime the fridge stop working and I have to change the temperature regulator (i think it is the thermostat) and then to unplug from the electricity and to plug back the fridge in order to make this works again. Btw there is only one temperature regulator for the fridge and freezer.
Can someone tell me if this problem can be related to the thermostat or to any other part easy to repair?
Thank you in advance for any help
29-11-2011, 10:38 PM #2
Re: Fridge Stop working sometime
replace thermostat and/or defrost timer
29-11-2011, 11:20 PM #3
Hi thank you for your answer, where is defrost timer located? is it possible to test the thermostat and the defrost timer?
Thank you
29-11-2011, 11:41 PM #4
timer is fitted at rear of appliance but as it a beko u leave it long enough you will find it when it goes bang and up in flames lol
