Results 1 to 47 of 47
Thread: T.E.V. adjustment.
Threaded View
12-01-2010, 02:01 AM #30
Re: T.E.V. adjustment.
What they taught you at college is indeed correct. I had this happen in a system that had been undercharged and ran for a long time. The system was a blast freezer running R502. At the end of the cycle when there was little load we started to get flood back. That was an easy one to figure. The process is called wiredrawing. It seems to be more pronounced on ammonia systems. Steam does this as well. Anytime you have a mixture of liquid and gas this can occur.
Expantion valve adjustment
By ayaz in forum Technical SpeculationsReplies: 5Last Post: 22-04-2006, 03:43 PM -
Pressure control adjustment and Case temperatures
By mccoolair@yahoo in forum Supermarket RefrigerationReplies: 3Last Post: 08-04-2006, 12:21 AM
