Results 1 to 20 of 20
    Dec 2004
    Weihai,China
    800
    underfloor heating and cooling
    Hi Dear all,
    Underfloor heating is popular in cold area of our country and is moving to the southern area(rather cold in winter)but it seldom applies to summer cooling. It's an energy save tech due to lower water temp for heating and higher temp for cooling. Would you tell me something about your country's application? and the main concerns in practical operation? thx!
    regards
    LC
    Jun 2005
    California
    394
    Re: underfloor heating and cooling
    Ic Shi, This may be a good source of information for you
    http://resourcecenter.ashrae.org/sto...ng&method=and&
    Aug 2005
    5,302
    Hi LC,
    Are you talking about underfloor heating or radiant panel systems?
    Here are several links on radiant panel systems for your review.
    http://www.radiantpanelassociation.o...cfm?pageid=136
    http://www.twapanels.ca/
    http://oikos.com/esb/37/radiant.html
    http://www.toolbase.org/techinv/tech...chnologyID=108
    Regards,
    US Iceman
    Oct 2003
    5,630
    34
    For cooling, Lichuan, I shouldn't use it.
    It will give a uncomfortable feeling because the cold will stay against the floor .
    If you walk around in summer with light shoes, you will feel the cold at your feet but that's all.
    What about condensation on the surface if you wants to lower the room temperature?
    Dec 2004
    Weihai,China
    800
    Hi Peter,
    Yeah,cooling floor is not popular as cooling ceiling because the lower temp on foot is uncomfortable. But combine floor heating with cooling can save initial and maintenance cost,the condensation problem shall be solved by room dewpoint control. I'm not sure if this tech has market potential-
    regards
    LC
    Oct 2003
    5,630
    34
    This is the webiste from Velta, products we sometimes use http://www.velta.de/en/start_fachhan...ht.htm&index=8
    And their practical tips of teh month
    http://www.velta.de/en/start_fachhan...t.htm&index=46
    Feb 2005
    Malaysia
    7
    Hi Lichuan
    You can try http://www.devi.com
    Freddy
    Jan 2006
    romania
    59
    Hi LC, in my house I had 120 sqm of floor heating. It`s a dream compares with conventional systems. I worked with GIACOMINI . The comfort is very high and the gas consumption is 10% lower ! Please note : very important is the house insulation . I built my house with 10 cm polystirene external insulation , because in Romania in the winter can be -30 Celsius degree (sometime).
    Best regards,Marian
    http://www.giacomini.com/giacomini/a...=4&id_domain=3
    Aug 2005
    iraq
    67
    130
    hi
    it is not practical in cooling ,,cause the cold air is heaver than the hot air,so most of cold air stay neer the floor and do not distrubute to all room volum
    this condition i see it in jordan (i live there 5 years)
    many of hotel room changed it underfloor cooling to fan coil cooling , is is mutch better
    thanks
    Dec 2004
    Weihai,China
    800
    How the external insulation to be done? what about the cost? thx
    there are some issues: #condensate on the floor if the air dew point higher than cooing surface temperature
    # to prevent uncomfortable cold breeze on foot,the floor surface temp shoudn't be too low, which limit this kind of system's capacity
    rgds
    LC
    Jan 2006
    romania
    59
    Aug 2005
    iraq
    67
    130
    Quote Originally Posted by lc_shi
    rgds
    LC
    hi
    the temprature of floor is above dew point,and the ambient temprature max.is 30 c so it is not so hot for design of cooling coiles with respect ambient temp.
    and there is no unconfortable feeling neer the surface ground
    all of that ,,,and i can tell it is unsuccesfull for cooling
    Mar 2006
    India
    80
    70
    Dear LC
    I find your posts about energy efficiency in HVAC very intersting.
    Many of us ,never looked at the energy used by HVAC equipment during our practicing days.
    I have recently designed a HVAC system for a four story building in India,using displacment ventilation.The air was not moved under floor, instead columns were used as diffusers with air velocity near 66 FPM (0.3 m/s)
    The cooling is achieved by indirect evaporative coooling and (small ammonia chiller comes on for dehumidification during muggy weather) with
    heat recovery from the return air .Thehumidified return air precools the incomming fresh air over a heat pipe heat exchanger before exhasting.
    You are right it is more effivcient and also offers the best indoor air quality
    rgds
    darshi
    Dec 2004
    Weihai,China
    800
    Hi Darshi
    Your project is very interesting. I hope you can share something with me. How about the small ammonia chiller and heat pipe HX? really a good topic
    if convenient,you can give my email :lc_shi@163.com
    best regards
    LC
    Mar 2006
    Glasgow, Scotland
    177
    Mar 2006
    India
    80
    70
    This is a good place to know a lot more
    www.ambthair.com/dispvmixed.html
    Coldroom System's Avatar
    Coldroom System Guest
    If anyone needs electric underfloor heating for Freezer Warehouses(not homes), contact
    James E Choate and Associates in Atlanta. They have designed thousands of systems all across the world. They have been doing it for 30+ years.
    770-448-8473
    Aug 2005
    5,302
    Dear Coldroom Systems,
    Please do not post the same message in multiple threads. This will not provide any additional benefits.
    Also please see my PM to you concerning the use of the RE site for advertising.
    Thanks and Best Regards,
    US Iceman
  19. #19
    MandyTossman's Avatar
    MandyTossman Guest
    Under Floor Heating mats [warmyourfloor.com] are DIY friendly. wiring should be done by an electric professional.
  20. #20
    jason.baptiste's Avatar
    jason.baptiste Guest
    The efficient way that the floor is heated means less heat loss, even distribution of heat, lower operating temperatures, healthier and more comfortable environments and greater design flexibility. All of these mean that underfloor heating is Eco-friendly, uses less fuel, can be used with alternative heat sources and operates at a lower cost than conventional systems.
  1. Heating / Cooling Control
    By walden in forum Electrical
    Last Post: 16-04-2006, 01:20 PM
  2. cooling tower without fillings
    Last Post: 27-12-2005, 12:55 AM
  3. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
  5. Regulation of cooling capacity
    By npaisnel in forum Domestic
    Last Post: 08-02-2002, 11:22 PM
