Thread: Egelhof Tev's
18-10-2005, 07:16 PM #1
Egelhof Tev's
any body know where i can get information relating to factory preset superheat settings on EGELHOF TEWL expansion valves for r404a?
its roughly the same size as a danfoss TE2.
any help would be appreciated,
thanks
18-10-2005, 11:42 PM #2
Re: Egelhof Tev's
Try this web page might be of help, i used the RTC type years ago, HRP in U.K used to stock these. Can be stripped and repaired when motor jams . http://www.steefane.com/catalogue.html P.s scroll down this page to e= expansion valves.
27-10-2005, 07:44 PM #3
Re: Egelhof Tev's
I have an old Egelhof catalogue. It states - Superheat Factory setting: 4K static superheat, applies with normal air conditioning range to a bulb temperature of 0 degrees C, applies within low temperature range to a bulb temperature which corresponds to an evaporation pressure of 1bar (according to refrigerant).
If you need any more info let me know
Upside down TEV's
By Latte in forum Technical DiscussionsReplies: 26Last Post: 15-03-2007, 12:23 PM -
Problem with three evaporators and TEVs
By lana in forum Trouble ShootingReplies: 16Last Post: 13-01-2006, 09:52 AM -
AKV versus TEV
By Peter_1 in forum IndustrialReplies: 43Last Post: 08-01-2006, 01:55 AM -
Adjustable versus non-adjustable
By Dan in forum Ye Old Wifes TalesReplies: 39Last Post: 03-12-2005, 10:41 AM -
Balanced port TEVs
By Prof Sporlan in forum FundamentalsReplies: 22Last Post: 25-02-2002, 03:43 PM
