Results 1 to 15 of 15
23-09-2011, 06:24 PM #1
maxima 1300 compressor snapping cranks ?
hi any one out there haveing the same problem ? help
23-09-2011, 07:49 PM #2
Re: maxima 1300 compressor snapping cranks ?
That's a new one on me. How many?
What year and hours? Anything loose?
23-09-2011, 09:51 PM #3
not really a new thing, we replaced a few of them... pls give some more info on what happened... usually they fail when the clutch is worn out and unit runs for a long time like that
23-09-2011, 11:30 PM #4
Where are the cranks broken? Inside the compressor or where the clutch mounts?
02-10-2011, 08:56 PM #5
there snapping half down the crank
02-10-2011, 08:59 PM #6
also need some help with sl tci code 48 clutch good engine speeds ok alternator charging 400htz any ideas help
03-10-2011, 08:41 PM #7
Check the rpm in the display. If the W wire has a high resistance it will give a false reading.
12-10-2011, 09:28 PM #8
a maxima 1300 snapping cranks is a design flaw it happen every single one of them at some stage the end of the crank fatigues orver time and then snaps
14-10-2011, 12:13 AM #9
never had it sounds like something is out of line?
14-10-2011, 08:53 PM #10
15-10-2011, 10:46 AM #11
design flaw my backside i seem to remember tk did exact same thing would suggest checking why did the cluth shoeslock up etc etc poor maintenance vibration belt tensions and so on
15-10-2011, 05:38 PM #12
clive is right, on maxima's problems come mainly from the clutch... if it is to worn out , the little springs that hold it closed will fall of... at this moment the shoes fail to disengage from the compressor when the unit stops....
a few starts like this and the crank will surely snap....
also when tightening belts always use a measuring tool...
15-10-2011, 09:29 PM #13
16-10-2011, 09:21 PM #14
your right djbe but they pay in the end
16-10-2011, 10:03 PM #15
