Results 1 to 21 of 21
Thread: conservatory
21-09-2011, 08:58 PM #1
conservatory
hi guy, what size kw unit would i put in a conservatory 9.1m x 3.1 x 3.1. would it be better to put in a twin split?
21-09-2011, 09:04 PM #2
Re: conservatory
Hi Ronny
there are a number of good a/c specifiers here
which if you supply your standard a/c heat load conciderations to your post will be able to give you an accurate reply
this would also show your an engineer & not someone who should be calling one
R's chillermanIf the World did not Suck, We would all fall off !
21-09-2011, 09:10 PM #3
Re: conservatory
i am not an a/c engineer! but does this matter?
21-09-2011, 09:41 PM #4
Re: conservatory
Hi Ronny
who is going to fit the unit if your not mate ??
new law came out this year (july) that has made it illegal for the unqualified to touch this equipment
as you need an engineer/company to install
you be best getting a few quotes, note the make/model being offered to you
and then come back with these and we can give you a view of whats what
other than that, to get a good answer to your original question
you will need to list your heat loads - direction its facing, number of occupents, ect ect
21-09-2011, 09:58 PM #5
Re: conservatory
anyone?...
21-09-2011, 10:01 PM #6
Re: conservatory
ive been told fujitsu asyg24lf 7kw but it may struggle so x2 off one condenser.
the installers think that is too much and 2x 5kw would be better?
21-09-2011, 11:12 PM #7
Re: conservatory
Ronny
Giving a room dimension for a conservatory is useless, as per chillerman above, what orientation, what is the roof made of, how many windows and how big, is the room completely sealed from the rest of the house, what colour carpet is fitted?
All things that entail a site visit
alMostly found in the southern part of this green and pleasant land.
21-09-2011, 11:19 PM #8
Re: conservatory
all that would give an exact but is not needed to give a rough idea
21-09-2011, 11:24 PM #9
Re: conservatory
Ok Ronny, you're the expert! i mean what does it matter your conservatory is made single pane windows including the ceiling?
21-09-2011, 11:41 PM #10
Re: conservatory
ronni=typical rule of thumb 180w/m2
9.1x3.1x180=5.077kw
as a wall mount has a 3mtr air throw ud be best fitting a twin system if u fit 2 splits then get a hard wired controller and link them so they both operate off the same logic.
to be on the safe side 2x 3.5kw indoors on a multi split. good luck with fishing pipework through ur cavity as its an art to hide ur pipework,drain etc
22-09-2011, 12:21 AM #11
22-09-2011, 12:29 AM #12
Re: conservatory
Hi Mike
theres a deleted post there mate, think he might not been too impressed ther are no magicians or fairy god mothers here tonight...that can just give an answer without all the details, either that or he did not want to declare the colour of his carpet
22-09-2011, 12:33 AM #13
22-09-2011, 12:40 AM #14
Re: conservatory
I had to google what he called me!!
22-09-2011, 12:59 AM #15
Re: conservatory
Ole I know mate, you add 'olia' to it and its northern china I believe...must have been asking about his carpet that tipped himover the edge as have read back through and even I managed to keep it very tame for me Dont know why when they post, it just seems quite obvious now & with me probaly joining the job club tomorrow I not be doing a fellow fridgie out of work, thats for sure
22-09-2011, 01:05 AM #16
Re: conservatory
Ah sure it brings a smile to our faces, hope your job takes a turn for the better, i still reckon you should hold out for a cayenne!
22-09-2011, 09:07 AM #17
Re: conservatory
Look I work for an a/c distributer. My partners auntie is the one who want a/c. Her installers reckon 2x 5kw but the guy I work with says 2x 7kw and there is a huge difference, so I wanted to see what you guys Thought without having to write an essay.
22-09-2011, 09:29 AM #18
Re: conservatory
I want to pull some thing that is 27 cu meters, one guy says a piece string and one guys says it needs a rope.
Who is right! The devil is in the detail.
So to make a reasonable estimate, you need to write the essay.
But I think you are a rude Pryke. Prove us wrong!Last edited by mad fridgie; 22-09-2011 at 09:32 AM.
22-09-2011, 09:53 AM #19
Re: conservatory
another one! jog on mate not interested in proving nout to you. if anybody would like to be helpful please post if not and you just wanna try and be clever by adding your useless twerp dont bother.
22-09-2011, 10:22 AM #20
22-09-2011, 10:47 AM #21
- Join Date
- Jan 2001
- Location
- Fife, Scotland.
- Age
- 66
- Posts
- 1,103
- Blog Entries
- 2
- Rep Power
- 20
Re: conservatory
end off ............................................................................
