Results 1 to 9 of 9
    jomi69's Avatar
    jomi69 Guest
    Climaveneta CVM 3000 Nascosto Keys
    Can someone help with the CVM 3000 Hidden keys for accessing user and Factory Menus. Thank You.
    Apr 2006
    55
    1,908
    30
    Re: Climaveneta CVM 3000 Nascosto Keys
    Hi Jomi69
    I shall email you the manual
    R's CM
    If the World did not Suck, We would all fall off !
    Apr 2006
    55
    1,908
    30
    Hi Jomi69
    manual sent....but please be careful not to adjust anything that does not need to be
    the only thing you should need this access for is to calibrate sensors & transducers
    R's CM
    Jan 2012
    United Kingdom
    2
    Hi Chillerman 2006
    I have a manual that tells you details of sensor calibration and so on but it does not give you details of where the hidden keys are and says you should contact climaveneta. I would really appreciate these details if you could email me at tm.edwardmccarthy@gmail.com
    Thanks in advance
    Apr 2006
    55
    1,908
    30
    Hi teddymac
    its to the left of the screen, just run your fingers over pushing slightly to find it... you then press the hidden key and ice together
    chillerman
    Jul 2007
    Italy
    55
    Hi Teddymac,
    I hope you aren't referring to the procedure identified in the manual as a "Self-Calibration" ......
    This will work only connecting a small box called "Self Calibration Kit" to two specific analog inputs of main board.
    If you are trying the procedure withouth the "Self Calibration Kit" the final result could be a disaster!
    Regards.
    Apr 2009
    israel
    778
    Hi teddymac
    mail me i will send you the manual with directions .
    GOOD LUCK
    THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
    Jan 2012
    United Kingdom
    2
    Hi Goshen what is your email address ? Mine is tm.edwardmccarthy@gmail.com if you could mail me manual and directions that would be great.
    Apr 2009
    israel
    778
    did you get it ?
    good luck
