Thread: unknown compressorA/C
04-09-2011, 11:13 PM #1
have a retrofit to do on an A/C unit and a bit stumped with regard to compressor Hp etc, can anyone enlighten me with what the hell it is, attached is the only I.D on it
04-09-2011, 11:48 PM #2
Re: unknown compressorA/C
2T52 is close to a Daikin model number, but I can't find more than that.
What is the make/model of the equipment that it is in?Brian - Newton Abbot, Devon, UK
05-09-2011, 12:34 AM #3
You're spot on with regard to Daikin Brian, uncovered the evap and it's a Daikin model# FDY61 running R22,, 3ph 50hz and drawing 4.5Amps ( the evap that is) , condensing at present is salt water shell and tube condensor and client requires unit to be reverse cycle to heat as well as cool
