Results 1 to 14 of 14
    Apr 2001
    2,099
    27
    Door Heater Tape
    I need to fit a heater cable into a door frame, ( freezer room) to stop door sticking to frame.
    Not having ever bought one before, would welcome some advice on which type to buy and from where
    Abe
    Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
    Apr 2001
    2,099
    27
    Re: Door Heater Tape
    I did also ask some time back if it was ok to leave the evaporator condensate drain heater permanently on. It is not self regulating.
    Sep 2005
    uk
    499
    21
    best bet is to talk to a panel erector as they deal with doors and heaters day after day. they are usually a wide flat heater tape in the frame connected to a transformer box. in some cases when they go down it means a door off job. the heater tape can be left on all the time in a freezer, but if fitted internal to the drain make sure you dont have half of it dangling outside the box.
    Takes a licking, keeps on ticking.
    Mushtaq Kumbay's Avatar
    Mushtaq Kumbay Guest
    Freeezer door heater tape
    Try Scandia coldrooms.They supply mains voltage and also low voltage fed via step down trasformer.they come in 3 sizes 1/4,1/2, and 1 inch widthHope this helps
    Jan 2005
    Norfolk, U.K
    44
    65
    Try thermal dynamics or icefree
    Dec 2004
    Australia
    52
    519
    G'day Aiyub.
    Try this
    http://catalogue.actrol.com.au/ProductLookup.nsf
    Under search catalogue,type in heater cable.
    Then select springfield cable
    Oct 2005
    Canada
    35
    heater cable
    TRY RAYCHEM 611-250 HEAT SELF REGULATING TRACING CABLE, 6W/FT
    C/W H-900 TERMINATION KIT
    Camille
    Oct 2005
    Canada
    35
    heater cable
    Camille
    May 2008
    hungerford
    8
    icefree ltd (uk)
    can supply and advise on requirments they supply a no of types such as flat tape,cables, mains + low voltage
    Feb 2006
    derbyshire
    610
    first measure the door frame and total the length needed not forgeting the threshold under the frame or the bottom of the frame if it runs arround it like a square,add a mtr for termination tails and wastage,it will be 1/2 or 3/4" wide,take a trim off and check first then order it from thermo dynamics,icefree etc.
    have you checked the transformer out as its normaly the output fuse in the box,sure you have,check the voltage going to the tape against the tapping numbers inside the lid,also for high setting for a freezer,thats were it all go,es wrong,right output,right length tape,alls good,varie from that and its burnt out fuses,no heat,etc.good luck.
    Sep 2003
    ISRAEL
    72
    4,248
    Hello friend
    You do not "just fit" a heating strip.
    It comes in a special groove in the door frame, covered with a flat piece a aluminum for good heat transfer.
    I will post some pictures of the freezer I am working on now.
    Say Hello to my kid......
    Chemi
    11,025
    Sorry fellas, you're about three years too late
    Feb 2006
    derbyshire
    610
    "ooooooooooop,s" deffo will need one by now then
    Mar 2008
    Hereford
    Try Thermaldynamics. 01793431539. They can supply flat 1/2" or 1/4" heater tape plus transformer boxes. They will tell you what you need. I use them all the time.
  1. Vinyl tape for air-conditioner pipework
    By Stoofer in forum Air Conditioning
    Last Post: 11-07-2006, 10:17 AM
