Results 1 to 1 of 1
06-07-2011, 12:40 PM #1
Is IEC report 60335-2-40 self certifiable?
I am applying for the "Letter of Authority to Import" for an add-on heat pump water heater. In order to do so I was told I need to complete IEC report 60335-2-40 (Safety of household and similar electrical appliances--Part 2: Particular requirements for electrical heat pumps, air conditioners and dehumidifiers).
Is this test self-certifiable? If so, is there a template available that I can follow from line to line? I have found several copies of the report that Intertek and other testing companies have done that all follow the same format so I'm assuming there is one out there. I posted a link to the completed test from Intertek. Thank you for your responses.
http://www.airtradecentre.bg/PDF/new...t%20report.pdf
