Results 1 to 2 of 2
Thread: Daikin error code 6a
28-06-2011, 05:56 PM #1
I need to investigate a job in the next couple of days......
4 x daikin splits, each with own condensor unit.....unit 1 shows error 6a (thermistor/damper fault)....the others are belived to be ok. The system is fairly new but hasnt been maintained (dirty filters etc)......can someone please give me a steer in the right direction as i am usually involved with mitsi systems.......thanks
28-06-2011, 08:08 PM #2
Re: Daikin error code 6a
it is the damper motor limit switch which has not made on the heat recovery ventilation unit.
