    fridgetrouble's Avatar
    fridgetrouble Guest
    GAH rapier fans not working
    Should change my name to fridge virgin.
    Have a GAH rapier, set at 2 degres. the unit is cooling down both on road only and on standby to 10/11 degres and then cutting off.
    Fans on top not working/turning. Any idea ?
    many thanks
    Nov 2005
    uk
    8
    Re: GAH rapier fans not working
    Fans not working at all on the condenser on the roof? If not fuses usally blown 15 amp in a metal box in condenser/or in inline fuse holders
    Feb 2009
    telford
    2,090
    33
    yep check the fuses,the motors are more than likely u/s,on the later units they are thru a pressure switch so check that as well fuses first.
    Feb 2010
    aldridge walsall england
    43
    Hi also check the condenser fan relays as they can burn out (this is after you have checked the fans for being siezed or badly worn, check amp draw on each fan assy) make sure you fit the correct relays some GAH relays have a double 87 terminal. Also contact GAH for a wiring diagram, they are quite helpful.
    hope this helps
    regards
    Tom
    Nov 2005
    uk
    8
    where abouts in the uk are u,if your close ill fix it for a case of beer, 9 times out of 10 fuses blown after winter due to design fault.
