Results 1 to 17 of 17
Thread: Older LAE Controller
28-09-2005, 10:32 AM #1
I need to re program settings on a LAE controller fitted to a freezer room.
It has a fan delay function
Would anyone have the parameters and also which buttons I need to activate programming mode!!!
28-09-2005, 11:19 AM #2
Re: Older LAE Controller
Hi Aiyub,
This is my first post, so I hope it helps. Try going to www.hawco-refrigeration.co.uk in their technical support section they have pdf files for many LAE controllers. Hopefully they will have one for your model of controller as the parameters tend to differ from each model.
28-09-2005, 07:31 PM #3
Hi and welcome Maff, I was going to suggest Thermofrost but your choice is better.
28-09-2005, 09:18 PM #4
01-10-2005, 07:02 PM #5
Thanks all for your help
It was an older LAE MCDU11 Controller and I couldnt get any details on this particular model
01-10-2005, 07:28 PM #6
this is screaming at me that I have the set up book for this controller..I've just searched my file here and ca't find it -but I will still look some more..maybe not tonight but I will
cheers
richard
01-10-2005, 07:30 PM #7
i bloody well knew it..
send me a fax number and I will send you the full set up instructions
cheers
richard
01-10-2005, 07:38 PM #8
Thanks richard
Fax Number 0116 210 .....
01-10-2005, 07:56 PM #9
Got it Rich.............
My troubles are now over!!!
I "owe" you one
01-10-2005, 08:02 PM #10
Originally Posted by Aiyub
cheers
richard
01-10-2005, 08:10 PM #11
hi all
could not remember where i had seen this controller it was on the really older fosters cabinets
dug out the details but if you are ok if not i have the fosters version of the control
17-10-2005, 10:13 AM #12
technical back up for all lae controllers phone hawco refrigeration 01483869000
25-05-2009, 08:40 AM #13
Hi everyone
I stumbled on this site so I hope someone can help. I have a Friulair air dryer with a LAE controller, Model DMC20RI. If anyone has info on this controller, e.g. setup proceedures, parrameters etc. i would really appretiate it. I have tried the LAE site but this controller seems to have been discontinued.
25-05-2009, 11:21 PM #14
Hi Craig, welcome to the forum.
The following file contains programming details for your controller, amongst others.
Please note that the password is at the end of the document.
http://www.belairtech.net/manuals/di...S%20Manual.pdfBrian - Newton Abbot, Devon, UK
30-05-2009, 10:53 AM #15
15-03-2011, 08:24 PM #16
Hi rechard
I have changed Lae controller AD2-5C24W-AG to the old generation model that have recommended by HAWCO Refrigeration but not it work. I don't know how to program the parameter.
I do hope you may help with this horrible thing.
Please give me ring 07940873479 I will give you fax number at work. I can't give you right now because I can't remember.
Kinds regarding
Chan
17-03-2011, 09:49 AM #17
it do work !
In fact it works beautifully! Again if you bought it from hawco surely it would be a sensible idea to ring hawco technical help on 01483869069 of if you feeling really daring go to the technical help section of the hawco website (http://www.hawco.co.uk) where surprisingly you can download all the lae Eliwell and Carel instructions! Or buy pre programmed controllers then you don’t have to do anything !!
Micro-cool controller
By bernard in forum Supermarket RefrigerationReplies: 6Last Post: 25-08-2006, 07:10 AM -
Stiebel Remote Controller?
By Makeit go Right in forum Air ConditioningReplies: 7Last Post: 24-05-2006, 12:33 AM -
Help with new electronic refrigerator controller !
By EngiGal in forum New TechnologiesReplies: 17Last Post: 08-04-2006, 07:39 PM -
Controller wiring
By Mickvee in forum Air ConditioningReplies: 2Last Post: 30-12-2005, 02:04 AM -
Fan Controller
By Abe in forum Trouble ShootingReplies: 4Last Post: 12-01-2002, 02:21 AM
