Results 1 to 10 of 10
Thread: gas welding gear
23-04-2011, 12:45 PM #1
gas welding gear
I want to make a lightwieght gas welding kit for those awkard miles up ladders,corridors etc jobs, I know there exists an Mapp gas can type screw on with a standard hose connection for the BOC saffire type torch /hose ends but I cant find a seller,a mini oxy bottle is easy from BOC but is there an alternative if any one has a solution If so I might even make up one for the bench to save hauling the portpak out he van too
Dev
23-04-2011, 06:51 PM #2
Re: gas welding gear
rothenburger oxy/turbo kit from climate centre about £150 weigh next to nowt and good up to 2 1/8 pipe
24-04-2011, 08:41 PM #3
Any ideas how to get a mapp gas can onto one of those I have found that the fuel gas that comes with this kit pretty poor in comparison to mapp
Dev
24-04-2011, 09:30 PM #4
I have one of these,
http://www.westsidewholesale.com/ext..._-na-_-na-_-na
Have used on 1 3/8" or on drier changes etc.
And one of these,
http://www.ryanairconspares.com/turb...rch-p-243.html
Which is good upto 1 1/8" indoors.
If needs be i'll used two torches to get things hot enough quick enough and switch to one to braze.
Also got one of the rothenberger torches.
Think i got them from RPW/FSW.
JonMostly found in Oxfordshire, UK :)
25-04-2011, 11:36 AM #5
Hi Jon did you send to the US for this I see SRW (probably the most expensive wholesaler on the planet) have them
Devlin
25-04-2011, 11:38 AM #6
HRP can get the turbo snakes in on special order
25-04-2011, 01:12 PM #7
I got them from RPW who's now called FSW http://www.fsw.uk.com/branches.htm for their nearest branch.
The good thing with the turbo torch is that if the nozzle gets blocked up you can take the jet out and clean it. I would advise you put some thread lock on the hose connections as they can come appart, i did resent the price a bit but they do the job well which is all you can ask and are more reliable than the rothenberger torches and less hastle for small stuff than the oxy/ac.
FSW aslo do an oxy/mapp set up with a full size refillable oxy bottle but i don't think you will save much weight over a conventional set up.
I think Dean&Wood and HRP do turbo torch stuff too.
26-04-2011, 12:58 AM #8
26-04-2011, 03:31 AM #9
I use this one http://oldsite.stareast.com.au/Speci...2011_final.pdf
It's a Mapp Gas with an Oxy cylinder getting to 3050degC. Very small and light weight. It cost me $350. Unless I need to weld over 2" pipe then the old heavy welding set comes out.Last edited by Tesla; 26-04-2011 at 03:36 AM. Reason: I tried to post an image of item but it just had gibberish nubers and letters.
27-04-2011, 02:26 AM #10
I've bought parts off these guys but as i can't beam myself 2000 kms to their store, one has to weigh up the quality they distribute. So far though, the majority has been fine. bought one 630mm 240v fan/motor combo that lasted a few months only, so no joy there. Let me know how your map/oxy kit works out, as in how long the fuel lasts before having to replace bottles. Say hi to Mario next time your there.. Mike.
