Thread: Beko ab910
12-03-2011, 09:15 AM #1
Beko ab910
Hi there
I have a Beko AB910 side by side fridge freezer, the problem I have is the fridge is to cold, it has just started freezing things over the last day or so. I have put the temp up to 8 degrees but no difference, anyone have any thoughts?
Just to note the freezer is working fine by the look of it
12-03-2011, 09:28 AM #2
Re: Beko ab910
it also sounds like it is constantly running
12-03-2011, 10:07 AM #3
Re: Beko ab910
please ignore above post, it isn't constantly running!!
12-03-2011, 12:17 PM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Beko ab910
What temperature is displayed for fridge compartment?
If above 0, then fridge temperature probe is faulty.
12-03-2011, 04:48 PM #5
Re: Beko ab910
The temp on the fridge reads 8 degrees (as i turned it up to try and warm it slightly) and the freezer reads −18, the freezer seems fine.
i have put a glass of water in it to see if it still cold enough to freeze it, it freezes liquids in any part of the fridge as well, regardless if it is top, middle or bottom
12-03-2011, 06:10 PM #6
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Beko ab910
As I said, faulty fridge probe or some other element in probe circuit gives wrong information and fridg is working below freezing point.
You need service technician to check probe and fix that.
12-03-2011, 06:48 PM #7
Re: Beko ab910
is this not something i can do?
