Results 1 to 11 of 11
Thread: Daikin R407c RESYP10
14-02-2011, 11:24 PM #1
We have to replace the X22a SENPH hp sensor on this old VRV
Do we need to decant or are they 'safe' to remove
Richard
15-02-2011, 06:24 PM #2
Re: Daikin R407c RESYP10
Hi Richard,
VRV system before VRV III all had pressure sensors that could be replaced without having to recover the system charge. An easy way to tell is to look at the pressure sensor, if it has a brass nut at the top of the copper pipe brazed into the suction or discharge pipes, than you and remove it with recovering the charge. If there is no brass nut than its a braze in job.
Hope it helps.
Obi Wan
3 weeks and counting
15-02-2011, 07:34 PM #3
Thanks very much that's confirms our suspicions
17-02-2011, 04:59 PM #4
18-02-2011, 08:04 PM #5
All will be revealed soon
17-03-2011, 10:47 PM #6
Can you guess what it is yet?
18-03-2011, 06:45 AM #7
Have you gone solo Obi Wan?
Marc
18-03-2011, 07:10 AM #8
18-03-2011, 10:20 AM #9
I have indeed. After 23 years working for a UK Daikin distributer it was the right time to move on. I have set up a new Limited company and started trading on March 8th. So far things are looking good. I was gonna put a link to our website but not sure is it's the right thing on this forum (free advertising and all that).
Look us up.
Obi Wan
18-03-2011, 03:24 PM #10
Is it this one?
http://www.daikin.uk
18-03-2011, 04:41 PM #11
Congrats Obi Wan hope everything work out for you.
Marc
R407c top up.
By shannon.mynhard in forum Technical DiscussionsReplies: 3Last Post: 28-04-2010, 06:50 AM -
Daikin R407c Heat pump
By Gaz E in forum Heat PumpsReplies: 9Last Post: 22-01-2010, 02:57 PM -
Is POE bad for R407C ?
By Acrisoft in forum RefrigerantsReplies: 14Last Post: 24-09-2009, 05:24 PM -
R22 to R407c
By sacoolman in forum Air ConditioningReplies: 5Last Post: 15-09-2009, 08:11 PM -
Daikin r407c 2 pipe vrv ja fault code any offers?
By Contactor in forum Air ConditioningReplies: 11Last Post: 28-07-2009, 01:26 AM
