Thread: Haier au36
01-02-2011, 12:27 PM #1
Haier au36
Cassette type,someone taken over a shop with a couple in,no remotes so used universal remote and one works fine.
The other has the power led flashing twice,it receives the remote signal but doesn't change plus it won't switch power off,power led flashes as soon as the main switch is on.
Haven't seen these before but knowing the reputation Haier have I'm not too hopeful.
Had a look through other threads and tried googling but haven't found any info.
Suspect pcb's but not at all sure.
Any help appreciated.
BG
“Life is like riding a bicycle. To keep your balance you must keep moving” Einstein
01-02-2011, 05:30 PM #2
Re: Haier au36
haier technical 01909517663
01-02-2011, 05:54 PM #3
Re: Haier au36
Many Thanks
Spare Parts sourcing problems for Haier in UK
By acsspain in forum Air ConditioningReplies: 15Last Post: 12-01-2011, 08:47 PM -
Haier error
By for in forum Air ConditioningReplies: 3Last Post: 06-01-2011, 05:16 PM -
haier ac split
By jonjon in forum Air ConditioningReplies: 7Last Post: 29-12-2010, 11:14 AM -
Haier HSU 12HF03 Temperature Problem
By its1 in forum Heat PumpsReplies: 5Last Post: 21-06-2010, 12:08 AM -
Haier Commerical Cool Remote Problem
By Gymkata in forum Trouble ShootingReplies: 3Last Post: 10-06-2010, 10:50 PM
