Results 1 to 2 of 2
28-01-2011, 09:00 PM #1
2000 carrier trailer reefer. Does not stop start.
I was wondering if any can help with this year 2000 carrier trailer reefer. It goes continously heating and cooling. Thank you
29-01-2011, 03:50 AM #2
Re: 2000 carrier trailer reefer. Does not stop start.
First make sure that it is set in auto start stop. Second, battery voltage must be good and water temp also must be acceptable before unit will shut down. This as well as setpoint and minimum on time must be met before micro will allow shut down.
Check this and get back to us so we can help further.
Abbs
Carrier Ultra Reefer Unit, mid 90's
By CA51 in forum TransportReplies: 49Last Post: 10-02-2012, 08:45 PM -
Carrier Supra 750 wont run reefer says oil warning
By AussieRod in forum TransportReplies: 5Last Post: 03-03-2011, 09:17 AM -
Bypassing a smv valve on carrier reefer
By hzu in forum TransportReplies: 14Last Post: 04-10-2010, 06:13 AM -
Carrier 850 MT start problem
By Maya in forum TransportReplies: 5Last Post: 18-05-2010, 10:49 PM
