Results 1 to 2 of 2
Thread: maximum pipe run length
21-01-2011, 04:58 PM #1
Could someone tell me please what is the maximum length of pipe run you can have for a split system.
make is mitsu heavy industries cassette 5 kw cooling
pipe sizes are 1/4 and 1/2 inch could increase this size to 1/2 and 5/8 because this is the size of the flair nuts on the indoor indoor is on same level as outdoor.And was wondering will it make much difference if the unit is at max length from indoor or slightly over that length.
tnx
21-01-2011, 06:37 PM #2
Re: maximum pipe run length
afdt 50vn pipes are 1/4 and 1/2 max pipe run 30 m max height 20m precharged to 15m
capacity difference between outdoor and indoor in VRV
By balaji in forum FundamentalsReplies: 11Last Post: 05-12-2008, 02:36 AM -
Maximum flex length
By bernard in forum ElectricalReplies: 5Last Post: 20-09-2007, 07:38 PM -
Split System max pipe run length?
By fridge doctor in forum Air ConditioningReplies: 4Last Post: 18-08-2007, 01:14 AM -
extra length v pipe size v additional charge
By misterfixit in forum Air ConditioningReplies: 18Last Post: 03-01-2007, 07:57 PM -
Eqivelant Pipe Length
By frank in forum Air ConditioningReplies: 21Last Post: 26-03-2006, 12:20 AM
