Results 1 to 2 of 2
17-01-2011, 12:45 PM #1
Electra air conditioner doesn't bip anymore when using the remote control
Hi everybody! I've an air conditioner split Electra (the model that comes with 4 lights in the lower right corner in the indoor unit).
Yesterday the air filter light turned on (the most right one). I took them out and clean them, then I put them back and pressed the reset button for 5 seconds in the indoor unit. The problem is that now each time I use the remote control despite it works, it doesn't make the bip anymore.
Someone has any idea why?
BTW, the air filter has any special way to put it back? I believe when I took them out the effort was bigger than when I put them back...
Thanks in advance! Guillermo.
17-01-2011, 04:30 PM #2
Re: Electra air conditioner doesn't bip anymore when using the remote control
Even in Electra mini split, the filter doesn't get bigger after you wash it...
The "bip" is made by a small black beeper on the electronic board with the 4 lights.
I would not replace it as long as the other functions work well.
Every output from the remote to the unit makes the green light flash so you know that the output turned into input.
electra rc-3 remote control
By makis82 in forum Air ConditioningReplies: 4Last Post: 03-12-2010, 03:26 PM -
Electra Remote control RC-3
By acollee in forum DomesticReplies: 2Last Post: 05-08-2010, 03:19 PM -
Airwell / Electra remote control
By cciutat in forum Air ConditioningReplies: 2Last Post: 04-08-2010, 04:02 PM -
Lost Remote Control for Split System AC
By kiamaian in forum Air ConditioningReplies: 5Last Post: 12-04-2009, 06:12 PM -
Remote Control problem
By botrous in forum Air ConditioningReplies: 2Last Post: 12-10-2005, 05:36 PM
