Results 1 to 8 of 8
15-08-2005, 09:42 PM #1
Oil line to compressors from temprite separator
Hi ive been working on some R22 HT and LT packs....ive been having trouble with oil getting back to the compressors....ive changed the filters in both the temprite separators and yes they did look kinda dirty. ive reassembled the separators and still couldnt get the oil back....i noticed there was a pressure regulator just after the oil service valve at the bottom of the separator and there was no oil flow through no matter where i put the set point.... anyway i changed it and now have oil passing but have no idea as to what pressure to set it too...on the HT pack the discharge pressure is around 15 bar and would just like to know if anyone knows the correct pressure the oil lline should be???? thanks to anyone who can help
rob
15-08-2005, 09:52 PM #2
Re: Oil line to compressors from temprite separator
1.2 to 1.5 higher than the crankcase pressure.
There are special differential pressure valves developed for this with a factory set DP over it.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
15-08-2005, 10:05 PM #3
We have had several sites we have taken over with this same problem recently, if there is one seperator/resevoir for all compressors on the rack
we have removed the low pressure system and installed Traxoil Electronic high pressure floats on each compressor and made the system into an HP system. We have also removed most of the temprite seps and installed good quality helicals.
15-08-2005, 10:23 PM #4
Hi Rob I don't know what type of pressure regulator is there, but normally the oil line pressure should be 1-1.5 Bar greater than the compressor crankcase pressure.
19-08-2005, 09:15 PM #5
cheers chaps you have been a help
rob
21-08-2005, 12:45 AM #6
Rob, we have been frustrated with the regulator that Temprite has been using. It is basically a downstream pressure regulator (CPR valve) that does not read differential pressures. You have to set the valve at least 40 psig over the suction setpoint to have a hope it feeds sufficiently throughout the gamut of suction pressures considered normal. Sporlan makes a .. hmm.. y1236 ??? differential valve that controls quite nicely relative to suction pressure. Yank out the downstream regulators and put the differential regulators in their place. Then you can trust a positive and regulated pressure feeding the oil to the oil regulators regardless of suction pressure changes. You only need 10 to 20 psig.
I don't know why the Temprite people haven't gotten the message yet.
21-08-2005, 11:40 AM #7
Originally Posted by paulcollis
And what brand of compressors do they use mainly down-under me?
Are larger supermarkets mainly equipped with packs?Last edited by Peter_1; 23-08-2005 at 05:03 PM.
23-08-2005, 08:16 AM #8
thanks chaps.....
Bearing trouble - rotary compressor
By rosetennis in forum Industrial CompressorsReplies: 6Last Post: 18-05-2006, 01:26 AM -
Parker levels in ammonia systems
By Friobernal in forum IndustrialReplies: 3Last Post: 04-08-2005, 03:46 PM -
Minimal required R134a speed in suction line
By DaBit in forum CPU OverclockersReplies: 32Last Post: 08-05-2002, 05:19 AM -
Line Sizing and Piping Practice
By subzero*psia in forum CommercialReplies: 1Last Post: 22-06-2001, 03:47 AM
