Thread: Glycol Back To Refrigerant
15-08-2005, 02:49 PM #1
Can anyone assist by telling me the best way to flush a glycol system evaporator on a serveover counter to be used as a refrigerated one or can you get a small glycol unit to run just a counter
thanks
15-08-2005, 07:44 PM #2
Re: Glycol Back To Refrigerant
Hi JIMMYBOY.
Cleaning us simple but, is the coil can be used for refrigerant?
Or was it designed and made for water and glycol?
I would strongly advice you not to do it.
Get a new coil, designed for refrigerant
Chemi
15-08-2005, 11:29 PM #3
JimmyBoy, welcome; if the systems has always run on glycol then I would assume that the pipework is NOT suitable for refrigerant - different grade of tubing and jointing.
It should be possible to get, or make, a small water cooler from which the chilled water could then be circulated around your existing coil.Brian - Newton Abbot, Devon, UK
16-08-2005, 08:11 PM #4
everything looks good for gas just need best way of flushing and drying dont knopw if ofn would do
16-08-2005, 10:54 PM #5
Well you could try a propriety tube cleaner followed by a set of triple evacuations to dry it afterwards.
Liquid receiver
By Renato RR in forum FundamentalsReplies: 134Last Post: 02-03-2011, 06:55 AM -
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 12:39 PM -
Milk getting into glycol on chill press
By balerjoe in forum Trouble ShootingReplies: 16Last Post: 06-09-2005, 09:41 PM -
which glycol to use ?
By dchatta in forum RefrigerantsReplies: 4Last Post: 12-07-2004, 09:26 AM -
Refrigerant Reclamation
By herefishy in forum CommercialReplies: 6Last Post: 23-07-2003, 08:19 AM
