Thread: Haier error
05-01-2011, 02:07 PM #1
Haier error
Hi! I have a problem with Haier inverter, one time it showed error 14. I turned it off, then started again, and everything was normal. What does it mean?
Thanks.
05-01-2011, 06:34 PM #2
Re: Haier error
This is all I have on these...
Haier Fault Codes
1 Flash = Indoor Temperature Sensor faulty
2 Flash = Indoor Coil Temperature
3 Flash = Outdoor Temperature Sensor Faulty
4 Flash = Outdoor Coil Temperature
5 Flash = Over Current Protect
6 Flash = Pressure Protect (HP/LP)
7 Flash = 3Phase Protection
8 Flash = Communication Trouble between Wired Remote and indoor unit
9 Flash = Communication Trouble between indoor / Outdoor unit
10 Flash = High Condensate Level
and go get a cuppa
06-01-2011, 03:50 AM #3
Re: Haier error
If it is simple 14 ( for example model HCFU-42CF03 with wired controller YR-E2) - "High pressure abnormal" - High pressure switch acts 3 times in 30 min.
If it is - E14 ( for example model HSU-09/12HVA103) - "Indoor fan motor malfunction" - breaking of wire inside the fan motor, breaking of the fan motor lead wires, faulty indoor unit PCB or Hall IC.
06-01-2011, 05:16 PM #4
Re: Haier error
Thanks a lot, actually it's hsu... simple e 14. It shoul'd be the fan, thanks.
Mitsi Heavy E57 fault code in Error Log on wired controller
By back2space in forum Air ConditioningReplies: 10Last Post: 13-10-2010, 09:24 AM -
shining fault codes
By al in forum Air ConditioningReplies: 3Last Post: 17-07-2010, 08:34 AM -
which compressor is the best?
By cakabo28 in forum New TechnologiesReplies: 33Last Post: 19-08-2009, 06:44 PM -
Angelopo Sm2l Error E2 Please Info About This Error
By CHARLIEZOLO in forum CommercialReplies: 4Last Post: 23-12-2005, 09:00 PM -
By CHARLIEZOLO in forum CommercialReplies: 0Last Post: 22-12-2005, 03:47 AM
