Results 1 to 2 of 2
Thread: Carrier Compressors main bush
04-08-2005, 08:48 PM #1
Needs info for Carrier 06D/06E Main bush removal and insertion tool and Bush resizing calculation as these bushs are oversize and cutting is requried.
09-03-2007, 02:00 PM #2
Re: Carrier Compressors main bush
We had done the the overhauls and unit is working fine, but I asked again what is the procedure and tools recommended by carrier as it is not clearly mentioned in their 06D/06E compressor service books, How you remove and fix it without a tool and how much metal needs to be removed from the (oversize) bearings that it can be fixed in the housing with proper clearance(0.002"),
malik55
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
Carrier 06BA Semihermetic compressors
By Brads in forum Technical SpeculationsReplies: 4Last Post: 07-09-2006, 09:01 PM -
Carrier chiller oil migration
By lowtech in forum IndustrialReplies: 5Last Post: 30-04-2006, 04:11 PM -
carrier remote
By superswill in forum Trouble ShootingReplies: 2Last Post: 26-04-2006, 09:17 PM -
Compressor's volume efficiency
By John McGru in forum FundamentalsReplies: 0Last Post: 16-02-2004, 08:44 AM
