Results 1 to 8 of 8
Thread: Daikin vrv u4 problem
02-12-2010, 01:30 AM #1
Sir any one can help me find a solution,im havin a problem on u4 error( transmission wiring between indoor and outdoor unit)i have already check the wires but error still persist...unit installed with two evaporator in one condenser, but we took the one evaporator board to install to the other unit mean only one unit now is connected to the condenser,we have re-connected the F1 and F2 from the remaining unit properly but U4 code still persist...can you help me or redirect me to the right thread in this forum?tnx
03-12-2010, 07:48 AM #2
Re: Daikin vrv u4 problem
Try to reset the unit..
03-12-2010, 05:28 PM #3
Model numbers??
03-12-2010, 09:43 PM #4
Units will need to be correctly addressed; the outdoor unit is probably looking for the unit you have removed. Also be aware , running for long periods at low load can be fatal to the outdoor unit .
04-12-2010, 12:32 AM #5
04-12-2010, 12:35 AM #6
04-12-2010, 12:40 AM #7
04-12-2010, 01:51 PM #8
I dont suppose you could offer some advise or help on a problem i have been asked about? im more chiller biased and dont really get involved with the VRV/splits unless necessary..
1 x REYQ 12M7W1B LINKED TO
1 X REYQ 10M7W1B
13 X CASSETTE INDOORS AT HIGH LEVEL
7 X LOCAL CONTROLLERS
1 X DCS302 CENTRAL CONTROLLER
1 X DST301 SCHEDULE TIMER
THE WHOLE SYSTEM SHUTS DOWN AT INTERMITTENT TIMES ON U4 FAULT CODE
THEY FEEL THE CENTRAL CONTROLLER IS FIGHTING THE LOCAL CONTROL BUT CANT BE SURE
THEY RESET 1 LOCAL CONTROLLER TO CLEAR FAULT CODES THE WHOLE SYSTEM SHUTS DOWN
SOMETIMES LASTS 4 HOUR OR 4 DAYS NO RHYME OR REASON BUT I NEED TO GET IT SORTED ASAP
Any idea??
many thanks
Wilko
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
problem with DAIKIN FCQ 71 > i need technical book
By mimifrigo in forum Air ConditioningReplies: 7Last Post: 13-01-2010, 03:06 PM -
DAIKIN problem
By mimifrigo in forum Air ConditioningReplies: 3Last Post: 05-01-2010, 09:02 PM -
Samsung Vivace Problem AQV24VBCN
By goldpau in forum Air ConditioningReplies: 0Last Post: 18-09-2009, 06:28 PM -
Saunier Duval Problem
By mallorcanangel in forum Air ConditioningReplies: 1Last Post: 10-07-2009, 01:26 AM
