Results 1 to 11 of 11
Thread: Urgent G Fault Codes Needed
27-07-2005, 07:26 PM #1
Hey faulks , a customer just called and said that his aircon isn't working and that there are 2 LEDs lighting together . . . he said that the trade mark is GOLD . . . I assume it's a local TM manufactured in china , and i assume it's the same as GALANZ or HUALING or maybe Campomatic (GALANZ) so i need fault codes for chinese A/Cs urgently . . . taking this on consideration , most of the chinese manufacturers uses the same controls , one factory for PCBs and another one for A/Cs then assembly , so i think the control provider is the same . . .
Any help would be appreciated ....
Email : pja149@hotmail.com
27-07-2005, 08:23 PM #2
Re: Urgent G Fault Codes Needed
Hi Botrous,
I Have never seen fault codes in these mini splits.
I don't think there are any. Galants and Hauling are cheap stuff and don't last fora long time.
Sorry but this is not Daikin.
Chemi
27-07-2005, 08:40 PM #3
I know Chemi , they aren't Daiin and the are the century cheepos . . . i though maybe they had some good ideas in developping some fault codes system in their A/Cs .... anyways , hope that the LEDs go off after I fix the A/C , because the man is very bothered from seeing glancing LEDs in front of him . . .
Besides , try to tell a customer that he has a cheepos . . . he will transform into a beast trying to kill youuuuuuuuu . . . all customers thinks their A/Cs are the best of the market , although they know that when they bough it , they asked for the cheeposEngineering, sciences, math, physics and my brain will generate "not responding " soon
28-07-2005, 02:07 PM #4
There's usually a list detailing the led's on the inside cover or the electrical connections cover.
c ya
T
28-07-2005, 09:29 PM #5
Thanks techguy , i'll look for that
08-08-2005, 12:05 PM #6
It's funny how you put these cheap aircons in for friends even though you object and then when they stuff up you automatically become the warranty agent...
08-08-2005, 12:20 PM #7
Originally Posted by tontoEngineering, sciences, math, physics and my brain will generate "not responding " soon
08-08-2005, 12:25 PM #8
Sorry didnt mean that I was just commenting on jobs I have done for friends in the past....
08-08-2005, 12:28 PM #9
ok man no problem . . . when you want to install for a freind , try to get the best AC on the market , you will often see your friend ....
08-08-2005, 05:04 PM #10
Boutrus you are right, Try to get a best one, but I think Try to avoid to do any job for your friends because if a unit runs fine it is units performence, and if there is any fault it is your fault.
08-08-2005, 08:13 PM #11
Panasonic Fault codes
By ronaldo9 in forum Air ConditioningReplies: 31Last Post: 20-02-2011, 08:57 PM -
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
Daikin fault codes
By Markie in forum Air ConditioningReplies: 16Last Post: 13-01-2009, 01:58 AM -
Chigo Cpa-09co Fault Codes? E4?
By chigosimon in forum Trouble ShootingReplies: 5Last Post: 24-11-2007, 12:46 AM -
MHI, Sanyo & Fuijitsu Complete Fault Codes
By aeb200 in forum Air ConditioningReplies: 1Last Post: 16-11-2005, 01:11 PM
