Results 1 to 11 of 11
Thread: freezer not freezing
25-11-2010, 04:10 PM #1
i have a upright freezer (Frigidaire freezer elite)that is not freezing .it is cold in side but not freezing.it is switched on and the fast freeze is on and switched to max , can any one help?
25-11-2010, 04:14 PM #2
Re: freezer not freezing
Maybe lack of refrigerant.
25-11-2010, 04:33 PM #3
what should i do?
25-11-2010, 05:00 PM #4
You must call the service to charge the system or whatever could be.
Just tell me one thing. You tell me that you have switched the thermostat to the minimum temperature, right?
If the temperature can be reached the compressor should always working and that can open the possibility of lack of refrigerant. If some times the compressor stops it could be thermostat malfunction. What is real happened?
I'm supposing that fridge have one compressor dedicated to the freezer separated from the one that serves the refrigerated compartment.To make progress is never good enough, I want to do better and better and better
25-11-2010, 05:18 PM #5
hi dewisfamily. there are a number of things to test your f-f but unless you are an electrician or a fridge tec , qualified as such then it would be unwise for you to touch it or for any of our engineers to suggest you touch it. its a case of safety for YOU and others , please get a local fridge company to come out to you ,
hope you get it sorted . sedgy.
25-11-2010, 06:08 PM #6
hmm. If it is a problem of thermostat I think a person whom have little knowledge of electricity can replace a thermostat.
It's my opinion.To make progress is never good enough, I want to do better and better and better
25-11-2010, 06:14 PM #7
hi sandro, in Portugal maybe?
in the uk , no
by the way how is the weather there¿
25-11-2010, 06:21 PM #8
A little of cold. sometimes is rain.
And how is the weather on UK?To make progress is never good enough, I want to do better and better and better
25-11-2010, 07:03 PM #9
Even as a novice, there are certain things you can do to narrow it down. You can remove the panel(s) that hides the compressor section and thoroughly clean everything you see. Also, make sure the fan down there is working. It needs all the airflow it can get. Don't forget to reinstall the panel.
If there is a fan inside the freezer, make sure it is working.
If the freezer is empty, you can shut it off (unplug it) overnight and leave the door open to make sure it is thoroughly defrosted. If it then works, there is a defrost problem.
Let us know what you find.Last edited by Gary; 25-11-2010 at 07:06 PM.
25-11-2010, 10:44 PM #10
25-11-2010, 11:44 PM #11
hi .can the dewisfamily come back on to tell us if theire fridge is a fridge freezer or a fridge with a freezer box inside the fridge? it is only maners you know
LG Side by Side Fridge Freezer not cooling or freezing
By nickphill in forum DomesticReplies: 6Last Post: 01-04-2010, 11:29 AM -
Hotpoint Mistral Plus - freezer temp intermittantly goes above freezing!
By robinsmh in forum DomesticReplies: 0Last Post: 22-10-2009, 01:31 PM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
Food not freezing when freezer is full
By Ryan D in forum DomesticReplies: 12Last Post: 22-07-2008, 09:02 PM
