Results 1 to 1 of 1
Thread: Mr. Slim Heating Problem
13-11-2010, 12:50 AM #1
My MSZ-GE12NA w/MUZ outside unit was installed this summer. A/C temperature maintained at the SET temperature correctly. This was my first use of heat. I was surprised to see the temperature in this room rise to 74F when I have it set to 67F. I was originally using HEAT mode, but later restarted everything in AUTO mode to no avail. The heat just continues to pump out and the room has become uncomfortably hot. I am now trying a third option (AUTO mode but have turned FAN to quiet mode). In the first two attempts, the fan ran, I assume, high (it was in AUTO fan mode). Does anybody know how the Mr. Slim SHOULD work, i.e., always keep temperature fairly constant or not? Thus, is it time to call a service rep OR am I not reading the operations manual correctly? Any guidance on how to set this unit to keep a fairly constant temperature around the SET temperature (HEAT, not A/C) is welcome. Thanks.
Hitachi airconditioning problem
By mlaauwen in forum Air ConditioningReplies: 6Last Post: 14-07-2010, 05:28 PM -
Mr. Slim MCB tripping problem
By sachin230 in forum Air ConditioningReplies: 4Last Post: 04-06-2010, 09:55 AM -
Toshiba RAS 13 SKV problem....
By igi in forum Air ConditioningReplies: 17Last Post: 12-01-2009, 08:03 AM -
Daikin FDYP100 not heating
By murattahtali in forum Trouble ShootingReplies: 14Last Post: 07-05-2008, 12:48 AM -
r407c heating problem
By marinetech in forum Trouble ShootingReplies: 3Last Post: 04-01-2008, 04:11 PM
