Thread: I need your help
05-11-2010, 05:00 AM #1
I need your help
in the work place theres a produce case hussman multiple decks (2) 8 fts lengh 2 fans 1 for evaporator coil,the equipment is charged with the right charged but i cant get a low temp just 44 degrees (f) not less, so i dont know, if its that termostatic expansion valve is bad or some other problem, i hope your help thanks.
05-11-2010, 07:02 AM #2
05-11-2010, 07:44 AM #3
Re: I need your help
The setpoint is?
09-11-2010, 10:01 PM #4
I presume the sight glass is full. After checking the evap coils for no ice,
Check the super heat at each coil,
Check thermostat setting,
Check LP cut-out setting.
