Results 1 to 8 of 8
Thread: Honda Accord AC
10-07-2005, 12:22 PM #1
Honda Accord AC
Need help with a freinds car ac.
Compressor kicks in anmd out........makes a grumbling noise intermittent
Refrigerant charge is ok, compressor pump down is fine. Cant understand why compressor cycling on and off continuosly.
Please help.
Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
10-07-2005, 03:50 PM #2
Re: Honda Accord AC
If the gas charge is ok and provided that it has not been tampered with such as recharged in case it was overcharged or charged up with a restriction in the system I would go for not condensing and cutting out on the high pressure cut out. Normally you can have a feel of the liquid line as you would with a normal refrigeration system bur cars do run warmer.
What year is it by the way and is it manual controls or electronic control looking like a car radio?Last edited by Andy W; 10-07-2005 at 03:55 PM.
10-07-2005, 04:44 PM #3
Re: Honda Accord AC
Andy
Its electronic like a car radio facia.........
one of the later modelsAny opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
10-07-2005, 04:46 PM #4
Re: Honda Accord AC
Do I remove charge , vac it and refill ??
and if I refill, what amount of refrigerant do I put in???Any opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
10-07-2005, 05:11 PM #5
Re: Honda Accord AC
nie time of of ten the correct charge is either on a plate under the bonnet or in the manual..
usually about 800gms
cheers
richard
10-07-2005, 05:25 PM #6
Re: Honda Accord AC
The Honda Accord from 1998 onwards is charged with 500 - 550grams of R134a. Fortunateley for you your particular car is equipped with a self diagnosis control module, its just a matter of knowing how to gain access to the codes. Switch ignition on, depress and hold Auto switch, depress and hold OFF switch. If fault has been recorded the digital display will illuminate a fault code which will cycle between "88" and trouble code consisting of one segment of one of the "8's" every 1 second. Try the above, let me know the code (if one recorded and stored) and I will tell you what it relates to. There are 14 codes by the way. Hope the above helps.
10-07-2005, 06:03 PM #7
Re: Honda Accord AC
1)Check the high pressure, maybe the filter is chocked or the expantion is faulty.
2)could be the condensor fan is too slow or rotating in wrong direction.
15-07-2005, 06:59 PM #8
Re: Honda Accord AC
Andy W, Richard.....Jay
I took out all the gas............deep vacuumed.......weighed in charge in exactly 550 gms of R134
Working like a charm
Apparently he took it somewhere...........guy overcharged it..........just filled unit with gas.........dumped
System was tripping on HP
Thx for all your helpAny opinions, statements and facts expressed in this message do not constitute legal advice in any shape or form and is given for a general outlook in nature. You are advised to seek appropriate and specific professional assistance from a regulated and authorised advisor for definitive advice.
Honda has hot gas heating
By nova in forum TransportReplies: 18Last Post: 19-03-2006, 06:50 PM
