27-09-2010, 02:28 PM #1
Does any body know any thing about Grunaire mini Splt System
I need Help I have a Grunaire GMU183HX system . The name tag says it is 220 volt but it it trips one leg L2 when energized. It will operate with this leg tripped which means it is running off 120Volts hoe can this be happening if the system is designed for 220Volts. IT cools , reaches Temp. shuts down , starts back up when it calls for cooling, Changes speed works just like it is supposed to. Pulls between 8-9 amps on start-up backs off to 4-5 amps when running. Some one HELP !!!!
27-09-2010, 06:56 PM #2
Re: Does any body know any thing about Grunaire mini Splt System
There was a guy here yesterday with exactly the same problem! What are the chances eh!
27-09-2010, 09:52 PM #3
same guy !!! still no anwsers
28-09-2010, 12:06 PM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Did you measured 120V or you just presuming?
28-09-2010, 01:18 PM #5
I measured 120Volts . Also measured current 8.5 amps at start-up drops back to 4-5 amps when running.
09-10-2010, 03:11 PM #6
Daikin fault codes
By Chris2005 in forum Air ConditioningReplies: 45Last Post: 21-03-2012, 10:09 PM -
Burn out System, Clean up procedure. & Troubleshooting.
By altaf22m in forum CommercialReplies: 19Last Post: 15-04-2008, 07:03 PM -
What is System balance?
By shogun7 in forum Technical SpeculationsReplies: 56Last Post: 19-01-2006, 09:47 AM -
Mini duct system for Uk market
By aeb200 in forum Air ConditioningReplies: 4Last Post: 28-11-2005, 07:35 PM -
Refrigeration system proposal; comments please.
By DaBit in forum Technical SpeculationsReplies: 13Last Post: 01-01-2003, 03:42 PM
