Thread: Fujitsu AOT45LJAYL - error 0E
20-09-2010, 07:38 PM #1
I have error 0E on CONTROLLER PCB ASSEMBLY type AOT45LJAYL:K04AW-0400HUE-C1.
This error does not appear in service manual. What is wrong ? With this error the air conditioning not working.
Thank you.
20-09-2010, 10:40 PM #2
Re: Fujitsu AOT45LJAYL - error 0E
Hi Medvonok
Welcome to RE forums.
If my memory serves me correctly, error code 0E indicates high discharge pressure.
You're right in that this code is not listed in the service manual.
Hope this helps, Grahamen boca cerrada no entran moscas
21-09-2010, 07:17 AM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
On that model error codes are in this form:
0:00
0:01
X:1b
Your code does not represent actual display. Check code again!
First number before divide symbol is number of unit and number after divider is error code.
Also outdoor unit have on PCB signaling LED which indicates error by changing number of flicker. Check that too.
21-09-2010, 12:45 PM #4
My error code is: 0:0E (on the LCD)
LED of outdoor`s unit is ON (it means no error).
For high discharge pressure what sensor is defective? Can I identified by color ? Thank you.
03-10-2010, 10:15 PM #5
Hi there I have fujistu air con gives me error code EEE in the control switch. air con work fine for few hours then only gives error signal.I swap the indoor pcb and control switch they work fine. when I removed the float switch A/C work fine and drip water, so that I replace the switch still doing the same, my only and last doubt is drain pump if I remove that A/C work fine. is there any method of checking the drain pump,
thank you
Fujitsu AOY90TPAMF
By andy c in forum Heat PumpsReplies: 6Last Post: 08-02-2010, 04:22 PM -
your opinons on fujitsu please
By acgibo in forum Air ConditioningReplies: 18Last Post: 26-08-2009, 05:06 PM -
fujitsu wall mount volt free relay
By mike live in forum Air ConditioningReplies: 3Last Post: 09-04-2009, 08:26 PM -
Fujitsu PCB
By gwilliamson in forum Air ConditioningReplies: 6Last Post: 10-09-2008, 10:27 PM -
Fujitsu or not?
By LRAC in forum Air ConditioningReplies: 14Last Post: 29-08-2007, 09:45 AM
