20-09-2010, 02:47 PM #1
Carrier XR Centrifugal Chiller(400RT) Problem
Dear All,
In our building,when we start two of Carrier XR Centrif: Chillers,the starting ampere is ramped up to a level and very slow to go down to normal running ampere.
I'd like to know it is because of soft starter problem or Compressor motor problem? Or other refrigeration problem?
Please help to give your suggestion.Thanks.
20-09-2010, 03:13 PM #2
Re: Carrier XR Centrifugal Chiller(400RT) Problem
inside rich programming panel is activated loanding ramp function?
20-09-2010, 03:35 PM #3
I'm not from chiller background and not sure how to check.Thanks.
20-09-2010, 05:58 PM #4
In that case call in Carrier Service Singapore
22-09-2010, 03:36 PM #5
Danfoss ICAD/ICM Valve problem
By piewie in forum NH3Replies: 3Last Post: 11-09-2010, 09:20 AM -
Carrier Chillers
By Ed Burris in forum Technical DiscussionsReplies: 6Last Post: 27-03-2010, 02:00 AM -
Problem with centrifugal chiller
By engalmohannad in forum CommercialReplies: 0Last Post: 19-04-2009, 10:00 PM -
Carrier 17P Centrifugal
By tgreer in forum Industrial CompressorsReplies: 4Last Post: 20-12-2008, 05:03 AM
