    chadng's Avatar
    chadng Guest
    r290 replacement for r134?
    can i replace my r134 refrigerant to r290? if not what refrigerants are interchangeable with r290.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: r290 replacement for r134?
    The refrigerant mass flow for R134a is higher than for R290. And POE oil is not completely miscible with propane... I would not suggest so.
    I would stick to R134a, despite I understand it being difficult to source in your country.
    Apr 2010
    philippines
    36
    Quote Originally Posted by chadng View Post
    Why do you want to replace R134 with R290 in the 1st place? and what is your application?
    Jun 2009
    Arrentela
    36
    32
    I use r290 as a direct replacement for R134 in my car AC. The oil is SW100, intented for R134.
    You must change the TXV or cappilar as flow is differnt and if only using R290 charge about 10% in weight of R134.
    The stuff is really cold, and it uses a lot less of power for the compressor (I changed because R134 would turn to much load on my engine on really hot days) I stick to propane only because 120g will do the job, that's enought to blow anything in case of any leakage or accident
    If on a stationary aplication you may be better of using a mix of 40% r600 and 60% r290. This is a direct replacement, used on R12 ans it works with R134 too. I've tried with both oils and don't have any compressor damaged in about two years. Mostly for fridges.
    Jun 2009
    Arrentela
    36
    32
    Quote Originally Posted by ctscasemod View Post
    By the way, If charging the 60-40mix charge about half the weight of R134 as this refrigerants are lighter (1Kg R134~0.5l)
  1. R22 replacement
    By brad__34 in forum Refrigerants
    Last Post: 04-06-2010, 09:06 PM
  2. Replacement for R403b
    By fridgability in forum Refrigerants
    Last Post: 20-08-2009, 03:36 PM
  3. R290 /R290a
    By CONROD in forum Refrigerants
    Last Post: 24-01-2009, 09:48 PM
  4. R290?
    By andyh in forum Refrigerants
    Last Post: 22-09-2007, 06:42 PM
  5. F 11 replacement for flushing
    By andrewuk in forum Refrigerants
    Last Post: 17-10-2003, 11:03 PM
