Thread: Technical details on Refrigerant
01-09-2010, 07:52 PM #1
Hello All,
please kindly inform the details on choosing refrigerant for air conditioning and refrigerant applications (irrespective of regulations, considering only technical aspects).
1. what is the typical choice of refrigerant for air conditioning and reasons for it.
2. waht is the typical choice of refrigerant for refrigeration and reasons for it.
Thanks in Advance!
01-09-2010, 11:12 PM #2
Re: Technical details on Refrigerant
The choice is generally made by referring to the temperatures that you want to achieve.
With packaged AC units it is decided by the manufacturer.Brian - Newton Abbot, Devon, UK
02-09-2010, 07:43 AM #3
1) R410A, R134A, R407C
2) R404A, R507A, R717, R744
Brian already answered for the technical reason. Basicly, what we want to achieve is the highest possible evaporating pressure compared to the evaporating temperature, to reduce the compression ratio and the compression heat as much as possible.
05-09-2010, 12:22 PM #4
thanks to both of you for your reply
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
charging refrigerant
By tichyt in forum Air ConditioningReplies: 20Last Post: 01-08-2010, 05:50 AM -
MHI FDCA400HKXRE4 Tech Info Please
By L.JT in forum Trouble ShootingReplies: 5Last Post: 23-08-2008, 11:00 PM -
converting refrigerant volume to mass
By tiggla01 in forum Tools and CalculatorsReplies: 2Last Post: 06-06-2008, 02:06 PM
