Results 1 to 8 of 8
Thread: Toshiba
    Mar 2004
    624
    21
    Toshiba
    Is it just toshiba who solder a 5 amp fuse on there P.C.B. board.So annoying,I think it is a real con,so I soldered a fuse holder in place,do they really expect people to buy a new P.C.B board?Why is there also a resistor with a glass case round it.
    Regards Bernard
    Jan 2005
    48
    64
    Re: Toshiba
    I have been told you can get "piggy back" fuse holders from somewhere like RS.
    Thse clip onto the connections of the broken fuse and you then insert a new fuse.
    Dec 2004
    Australia
    52
    519
    Re: Toshiba
    No not just Toshiba...
    Daikin are soldering fuses on the boards of their latest inverter wall mounts. 3.15a
    Also found an LG with a soldered on fuse.
    Just solder on a new fuse.
    Usually if fuse is blown then board is probably no good.Varistor might be shorted or various other problems.
    Mar 2004
    624
    21
    Re: Toshiba
    Its not so easy to solder a new fuse in as you tend to find the solder within the fuse melts even with a heat sink.If you buy a new board and that fuse blow it can become expensive.
    Regards Bernard
    Oct 2004
    Scotland
    1,454
    21
    Re: Toshiba
    Hi Bernard
    Why not just take the old fuse off and solder in some 5amp fuse wire?
    and go get a cuppa
    Jan 2005
    48
    64
    Re: Toshiba
    Why not use my idea,am I invisible?
    Mar 2004
    624
    21
    Re: Toshiba
    Who said that?
    Sorry I couldn,t resist it,I had a quick look through R.S cat today but could not see them,they would be ideal.
    Regards Bernard
    Jul 2005
    Ireland
    57
    164
    Re: Toshiba
    Hi B
    normally when a unit has a soldered fuse on the board there is a second plug for the offending cable or cables on the secondary side of the fuse IE. u get one chance if u blow the fuse u can bypass it. If the Varistor is blown just break it off the board its only there to blow in case of an overload or bad wiring. Manufacturers don't usually tell you this. Dont know how many mitsu boards i changed until I learned this simple fact. Mitsu dont use soldered fuses but the Varistors do blow.
    C Ya
    T
  1. Toshiba Digital Inverter range?
    By Slim R410a in forum Air Conditioning
    Last Post: 18-10-2010, 02:45 PM
  2. Toshiba Warranty
    By gwilliamson in forum Air Conditioning
    Last Post: 17-05-2006, 05:59 PM
  3. Replies: 1
    Last Post: 19-02-2006, 12:08 AM
  4. Toshiba A/C Compressor size
    By Chris2005 in forum Air Conditioning
    Last Post: 10-04-2005, 09:21 PM
