Results 1 to 8 of 8
Thread: Daikin Urura srara & U0
24-08-2010, 04:27 PM #1
Please help. Is this normal?
got U0 error aFter 2 jears (no more than 1000-1500 hours of operation)
Leak in the system? Or is this normal?
Or possible EVV Failure?
Unit is not heating/nor colling just blowing air... compresor starts both blowers too. (on inner and outer unit).
thanks for info!!!
24-08-2010, 11:32 PM #2
Re: Daikin Urura srara & U0
Could be either, faults may not be normal but can happen.
You need an AC technician to check the unit.Brian - Newton Abbot, Devon, UK
25-08-2010, 06:58 AM #3
Shuld leak be vissible (oil stain) or not?
25-08-2010, 07:39 AM #4
25-08-2010, 01:36 PM #5
U mean the suction? Is it on a fitting or a crack on a pipe? What the operating pressures like?
25-08-2010, 06:46 PM #6
25-08-2010, 07:36 PM #7
Ah rite sorry brian. Well then get someone to look at it who knows what they are looking at so. I don't think I'm a doctor so I go to one when I'm sick!!!
25-08-2010, 11:06 PM #8
yeah well if it is on the suction line outside the unit then you should get your installer back as it looks like he should have pressure tested his installation.
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Mitsi City Multi VS Daikin VRV
By sumsor in forum FundamentalsReplies: 5Last Post: 14-07-2010, 05:54 PM -
Daikin going to pot?
By Clk320_Greg in forum Air ConditioningReplies: 16Last Post: 19-07-2009, 06:03 PM -
Daikin AC parts from UK
By skel00 in forum Air ConditioningReplies: 5Last Post: 05-04-2009, 01:24 PM -
Fixing Daikin A3 Error
By Stuffy in forum Air ConditioningReplies: 3Last Post: 27-03-2009, 06:02 AM
