    Feb 2009
    telford
    2,092
    33
    nice ice machine problem
    got a prob with this machine it makes ice but when the paddle stops it does not stop freezing,if i clear ice and start again watching ice start to form stop paddle s by hand it defrosts and drops ice should there be a magnet on paddle assy,but why does it work if i stop it by hand?
    Jul 2010
    Ireland
    43
    7
    Re: nice ice machine problem
    what make of machine is it.
    Feb 2009
    telford
    2,092
    33
    its badged [nice ice]
    Jul 2010
    Ireland
    43
    7
    Quote Originally Posted by cadwaladr View Post
    I would think that one of the paddles is damaged where they lock in or where the outside paddle stops against the paddle bar is damaged.
    Mar 2008
    232
    Have a look at the paddle motor shaft, check that the pin, some times a split pin,you might have damage to the plastic part of the paddle wheels, it might turn in water but when it hits the ice instead of swinging the motor to activate the switch it can spin on the shaft.
    Feb 2009
    telford
    2,092
    33
    this machine uses a sensor [transmitter] fixed close to the paddle wheel,and a magnet on the paddle assy
  1. Replies: 15
    Last Post: 02-01-2011, 01:26 AM
  2. Manitowoc Ice Machine
    By crazycohiba in forum Commercial
    Last Post: 27-08-2009, 05:19 AM
  3. Problem with freeze system on carpigiani machine
    By Ben Taylor in forum Trouble Shooting
    Last Post: 04-05-2009, 06:52 PM
  4. Oil change problem
    By murray75 in forum Technical Discussions
    Last Post: 06-02-2009, 07:20 AM
  5. York Chiller Excessive Purges Problem
    By imranmd in forum Commercial
    Last Post: 07-03-2008, 05:13 AM
