Results 1 to 2 of 2
    Nov 2008
    alberta canada
    27
    howden wrv 255 mk5 slide valve
    Cannot find anywhere in the manual on how to remove the slide valve guide block spindle. I have the plug on the bottom out but not sure how to remove the spindle, does it thread out or tap with a hammer?
    3,362
    Re: howden wrv 255 mk5 slide valve
    Tap it out with a soft hammer .
    It will have an alignment pin as guide block pin is eccentric for slide alignment .
  1. Howden slide valve problems
    By CanadianIce in forum Industrial Compressors
    Last Post: 29-06-2010, 04:38 PM
  2. Slide valve wear on Grasso screw after just 54000 Hrs
    By Lodiev in forum Technical Speculations
    Last Post: 14-09-2009, 01:21 PM
  3. calibrating slide valve on rxf control pannel
    By marley in forum Industrial
    Last Post: 30-08-2009, 06:26 PM
  4. LEV does not open
    By Yuri B. in forum Air Conditioning
    Last Post: 19-07-2009, 02:37 PM
  5. FRICK TDSH 233 Slide Valve and guide damaged
    By 404cab in forum Industrial Compressors
    Last Post: 30-07-2008, 11:24 PM
